96 Volvo 850 R ABS Module Wiring w/Pics
96 volvo 850R ABS Module wiring w/pics
I did the test procedure per Midwest ABS to check the ohms between the ABS connector and the wheel sensors.. all sensors should ohm between 900-1380. My wheel sensors all showed good except the right rear..
  • LF- 1129 ohms
  • RF- 1155 ohms
  • LR- 1123 ohms
  • RR- 0 ( I guess bad sensor or wire problem ? )
Share this
