Delta Link Repair DIY
As I’ve mentioned before, I have had a persistent “clunk” in my rear suspension and a “wandering” sensation at highway speeds.
S70, V70, 850, C70 Delta Link DIY
I tried the fender washer in the shock mount repair which yielded no change in the sound and then, just to make sure on the easy stuff, I ordered some new shock mounts from FCP Groton. I replaced them and still no change in the clunk.
A couple of weeks ago I decided that a Chief’s halftime Sunday project was to find out what the problem was. As soon as I jacked up the car it was apparent, I had over 1 inch (2.5 cm) of vertical travel in my rear trailing arm end links. The right side was the worst as I could actually see the ball joint that should have been immersed in rubber.
Rear End Suspension Link Replacement
Share this
One Reply to “Delta Link Repair DIY”
  1. The course teaches an introductory lesson in the
    UKs BS 7671, and why should anyone else stand in their way.
    And this was in electrical help a non-union shop.
    This is a very cost-efficientway of managing these systems.
    Well-maintained equipment, protective gear, and safe work practices help protect any
    company’s most valuable asset – its employees.
