I'm looking for a diagram of the pinout on my ECU. I am wanting to try out the SAS delete as outlined by Lucky from IPD as shown here: http://volvospeed.com/vs_forum/index.ph ... as-delete/
The directions are not that clear, but this is alot easier than the potentiometer method that I currently have. I like taking on new projects. I promise if someone gives me a clear diagram I will do a complete how to post with step by step pictures!
- Jesse
1998 S70 T5 SAS delete
Project: Volvo 850 Repair or Replace Punctured Oil Pan?
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
IVIUSTANG
Here you are people I did some digging and found these diagrams for the ECU pin #'s. I'll let you know how this works out.
- Jesse
- Jesse
- Side A of of ECU pinout
- 2010-07-30_005730_Connector_A.gif (4.05 KiB) Viewed 5360 times
- Side B of ECU pinout
- 2010-07-30_005837_connector_B.gif (4.25 KiB) Viewed 5360 times
IVIUSTANG
Moved the instructions from here to the top of the thread.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Looks good Jesse!
Definitely adding this to the repair database.
'98 S70 T5
2016 Chevy Cruze Premier
IVIUSTANG
If you want bigger pictures I can get them, just trying to save bandwidth
Edit: wiring is now fixed, also here is another how-to that I wrote up.
Summer: 2002 Triumph TT600
Fair Weather: 2001 S60 T5M
Winter: 2000 S70 AWD
Restoration: 1983 Mercedes 300CDT
IVIUSTANG
Thanks for the heads up on the wiring, the instructions have been redone
- Jesse
- Jesse
- Has thanked: 2655 times
- Been thanked: 1248 times
Outstanding, I will try this in the next week or so. Thanks Jesse.
I'll document my "progress" although it looks quick and painless.
Much better! kinda tricky getting that diode in there. watch our solder points though, they look like they need a little more heat.IVIUSTANG wrote:Thanks for the heads up on the wiring, the instructions have been redone![]()
- Jesse
