Engine Coolant Tempature Sensor Topic is solved
guest
Post by guest »
Hey guys,
I have a 98 s70 turbo 2.3L I need to replace the ECT and have no idea where it is located, so that i can replace it. please help ASAP!
thanks,
Brad Walker
[email protected]
Guest
Post by Guest »
I would also like to know where it is. I think mine is bad . would this sensor prevent the fan from coming on completely. when i turn the ac on the fan doesnt come on.
Guest
Post by Guest »
this is the engine coolant tempature sensor. it is causing my cooling fan to turn on and stay on, like the car is running hot. I have been unable to find the location of the sensor and the easist way to replace it.
digital2
Post by digital2 »
haynes manual for 98 s70 says u need to disconnect radiator top hose at thermostat housing.
disconnect temp sensor wiring plug above the power steering pump also.
