Check Engine Light
Carlos
Check Engine Light
Post by Carlos »
My check engine light on my 98 S70 came on right after I fueled up. It did this once before, I guess one day after I refueled. I took it to a local AutoZone so that they could hook up to the OBDII and read the code. The code came up as something with emissions problems. The guy told me it could be my gas cap leaking. He erased the code and told me to take the cap off and then put it back on. He told me to drive around and if came back up that I should take to a local state inspections booth to have it check for leaks in the gas cap. It has been about two weeks since it was checked at AutoZone. How true is this, I am thinking it could be something more like an EGR valve. Could someone please help? Thanks in advance. :?
chriskose
Year and Model:
Post by chriskose »
The gas cap could easily be the problem. The Volvos, along with many new cars, have a completely sealed fuel system and a leak anywhere in the fuel system, like the gas cap, would trigger the engine light to illuminate. I'm not sure how often the gas caps fail... but it's a good idea to check the cheap stuff first.
In the CD player now: Collective Soul
carlos
Year and Model:
Post by carlos »
I took my car to the Autozone again and the code the computer said is "emission system malfunction". I had the gas cap checked but it passed the testing. So does anyone have any ideas on what else it could be? Thanks in advance.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Did he tell you the number of the code?
Guest
Post by Guest »
Code number = 0440
matthew1
Site Admin
Post by matthew1 »
carlos
Year and Model:
Post by carlos »
thanks to all i finally took in to the dealer and had it fixed.
bmuldoon
Post by bmuldoon »
:? So what was the problem that the Dealer fixed? Why was the Check engine light on?
