Volvo 850 GLE battery drain Topic is solved
My 97 Volvo 850 GLE measures a 150ma battery drain with everything turned off. The car is totally stock. Before I chase a problem that may not exist, can anyone tell me if 150ma is a reasonable number? Thanks in advance. Wlutz
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Is it right after turning the engine off?
If so,wait around 10 minutes allowing the car to turn off all relays.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
Older cell-phones would charge at like 150-300ma typically. Could easily sap your battery after like 24 hours or so. If I were you, I'd leave your meter connected, and pull fuses one-by-one, until one of the fuses drops that 150ma to 20-0ma. That'll be your parasitic drain.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- misha
Yep...GLE is a 10 valve car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Found 2 suspects. Fuse 6 draws 9ma and fuse 15 draws 100ma. Fuse 6: the locking system, and fuse 15: OBD socket, courtesy lights, door open warning lights, remote operated central locking system. Any hints going forward? Thanks, wlutz
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
I had a mysterious battery drain in the glove compartment. I set my cell phone to record, then put it in the glove box and shut the door. Over time the door has warped and does not make adequate contact with the switch that turns off my glove box light. It was draining my battery over the course of 2 to 3 days. I ended up getting a trickle charger before I discovered the problem. I pulled the light bulb out. No more battery drain.
I've done the phone in the box trick already...also tested door switches. My next step is to isolate and disable the remote part from the central locking system. I appreciate any and all suggestions. Thanks, wlutz.
I replaced the central locking relay/delayed inside lighting, 205-206, with no change in drain. I tested all the interior lights, then I found that my car has a tilt sensor which is also supplied by fuse 15. Located it in the upper passenger side of the trunk. Disconnected module 7/100 and my current drain remained at 160 ma. Last December I used the camera on my new iPhone to verify that the light in the glove box is off when the door is closed. I wanted to verify that findingI so I hooked my meter as before and measured 160 ma and then I opened the glove box and measured the current drain and it was 160 ma again. Then I folded a 4x6 sheet of paper so it became a pad, held it over the glove box switch and closed the door. The current drain now measured 31 ma. I cut a leather pad 1 inch in diameter and 1/8 inch thick and attached it as shown with contact cement. Don't regret all the work I did by missing the camera test...it was a great learning experience.
