Bad ignition switch can do some very strange things. And the factory units basically all fail as they come up on 20 years old, it is just just a question of when.
My take on this is that if it's never been replaced then it is probably worth it to do anyway in your position, just so you can cross it off the list of electrical gremlin sources.
My '98 XC Just Died On The Road Topic is solved
- Has thanked: 292 times
- Been thanked: 765 times
Re: My '98 XC Just Died On The Road
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Well, wait until you get a load of this: Had one quick stumble this morning, then a bit later it quit again (I was outside of town) - before grabbing the phone to call roadside, I popped the hood and starting checking connections, starting at the battery.
The little nut that holds the "extra" hot wires to the positive terminal? It was loose - I guess loose enough to lose power. Finger tightened it and looked at the dash, numbers were back, and it started right up.
Butter my butt and call me a biscuit.
It's the simple things sometimes, no?
Thank You to everyone for their suggestions and advice, I do appreciate it.
1998 (late) V70 XC
2002 MINI Cooper S (modified)
1977 Triumph Spitfire
Those extra hot wires are the battery end of the B+ cable that feeds the fuse box you were looking at. Maybe clean up the connector surface and reseat everything when you get a chance.
A bad cable connection is much easier than so many other electrical problems, good news!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1848 times
- Been thanked: 1710 times
while you are in there tightening up the B+ cable, check the other end of it up in the main fuse box by in front of the brake booster (the kidney shaped one). The cable enters the front and is help in place by a nut. Check the color of the connector and nut. They should be shiny bright brass. Try looking at the cable below the connector there as they are prone to melting and shorting out. This issue seems to affect 99-00 most, but I have herd of it on 98 and oder.
- Has thanked: 1505 times
- Been thanked: 3818 times
Viking horns to Erik for the cable suggestion...post (2)
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
Glad you figured it out!!
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
I probably should have noticed it
, but it's a tumultuous time in my life right now.
I'll double check those other connections - getting little things done to put it on the market, to be honest. Suddenly single and have 3 cars, something's gotta go...
1998 (late) V70 XC
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Get rid of the Mini...keep the Volvo.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The MINI has been with me for 9-1/2 years. My Mistress (lol).misha wrote:Get rid of the Mini...keep the Volvo.
But I'm considering keeping both if I can sell the Spitfire
Being "Suddenly Single" I really have ZERO need for a "family truckster" though.
Decisions, decisions...
1998 (late) V70 XC
