'99 V70 Base; ETM electrical clip release Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Can't release ETM electrical connector. What's the trick?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 1505 times
- Been thanked: 3818 times
I feel always feel,like the village idiot trying to undo Volvo electrical connectors, and I do all sorts of electronic stuff.
- Has thanked: 1850 times
- Been thanked: 1712 times
I can't recall, but I have a spare base (non-turbo) ETM in the garage for my 2000 base project. I'll take a look and see if there is anything obvious as a trick that may help.
- E Showell
Thanks Neil. Much appreciated.
'95 855 auto (sold)
'95 855 auto (sold)
Actually found it in the large pile of bits! It is the same connector as the turbos but like all of them it is a swine to separate if it has not been disconnected in some time. Only way I have been able to do so is to use 2 pairs of adjustable pliers, soak the connector in silicon oil to try to loosen the dust and grit that gets in there, and then work them using one of the pliers to depress the lock tab downwards into the clip. It can take a while to do, but you have to be careful obviously not to squeeze too hard and break the connector.
Good luck!
Good luck!
- E Showell
Guaranteed this one has never been apart.
'95 855 auto (sold)
'95 855 auto (sold)
Sent email - picture of ETM connector apart here. Its simple...if you a Martian...
One hand compresses the tab on top
One hand grabs RHS
One hand grabs LHS
Pull
One hand grabs RHS
One hand grabs LHS
Pull
That works with a car that has never been outside. In the real world like where my cars live, the connectors almost feel like they have fused together. I was not able to grip them tight enough to be able to separate the 2 parts so ended up needing the 2 adjustable pliers to get enough grip while on was doing double duty of compressing the latch and flexing the connector. Even then it was touch and go if the connector did not break first. I have undone several of these at PnP over the years and they were all the same. The same connector is used in several locations around the engine bay and they have all been the same.
- E Showell
Just needed to pinch harder with right thumb and pull harder with both hands. No magic. Press down on clip and pull hard. The challenge is getting the pulling force on the horizontal given the short wiring harnesses and the miniscule space in which to move hands.
'95 855 auto (sold)
'95 855 auto (sold)
On the upside, the force required is overcoming the seals on these connectors which are really good. Thats why they don't get wet, and why they don't corrode after 20 years of service. I know its a pig, but we have to acknowledge the use of high quality , expensive stuff on these cars, where appropriate.
