S70, N/A,flash of ABS/TRACS light...[old dead battery] Topic is solved
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Re: S70, N/A, 5-Speed: Sporadic low speed wheel noise + sudden flash of ABS/TRACS light...
Post by theWIFES_S70 »
abscate wrote: 20 Oct 2018, 03:50 Why do you complain about a two hour trip up the Taconic when it’s two hours to get to BROOKLYN?
The whole point of ALB is to be a bit too far for NYC people .....
Well, we know how to complain in NYC... :mrgreen: I love driving on the Taconic! (And I love not paying tolls!)
June 1st weekend? June 8th?
Retired:
2015 Volvo S60, T5, 85K
Has thanked: 1505 times
Been thanked: 3818 times
Baird park looks great. Elizaville pulloff from the Taconic might be easier and free, too
About midway?
Fosgate
Year and Model: 2011 XC60 R-Design
Post by Fosgate »
If the problem is still there try replacing your auxiliary belt (the main belt that drives everything) if thats old and slipping you can have a noise from it and drop in voltage from the alternator that is not able to provide enough current at low rpm...
Had similar issue in the past month or two and replacing of the belt seems to solve it, my battery is only year old Varta unit...
theWIFES_S70
Fosgate wrote: 22 Oct 2018, 08:58 If the problem is still there try replacing your auxiliary belt (the main belt that drives everything) if thats old and slipping you can have a noise from it and drop in voltage from the alternator that is not able to provide enough current at low rpm...
Hey Fosgate, thanks for the suggestion. Belts were all replaced about 25K back. Will double-check.
Really wondering if I need to just replace my battery cables already... With the new battery haven't had any issues yet. Will definitely keep an eye on it.
Retired:
theWIFES_S70
About two months later and have not had another ABS/TRACS flash since I replaced my 6+ year old battery. Our cars really are sensitive when it comes to the electricity...
Retired:
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
We should still do a get together this summer.
Thanked original solution provider, apologies for gas lighting her/ him
theWIFES_S70
Yes! Will definitely reserve a bbq space at a park this summer!
Retired:
theWIFES_S70 wrote: 09 Dec 2018, 22:05 About two months later and have not had another ABS/TRACS flash since I replaced my 6+ year old battery. Our cars really are sensitive when it comes to the electricity...
I completely forgot about this thread but had exactly the same thing happen to my 99 T5 with a 7 year battery inDEC 2019. I put the battery in a 10 amp charger for a day and am doing that on weekends, so that I can get one more winter out of this battery , then replace next fall.
Upshot..a battery that cranks and starts the car just fine can still be too weak to reliably operate electronic cars, and the ABS seems to be the first thing to give symptoms.
Link to mine
viewtopic.php?f=1&t=92161&p=529749&hili ... ge#p529749
theWIFES_S70
I think these cars definitely need car battery intervals. A new battery completely fixed this issue. .
Retired:
