Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
:lol: :lol: :lol:
(You're preaching to the choir, in my case.)
1999 V70 GLT
Has thanked: 1505 times
Been thanked: 3818 times
Dr Oetiker here…you will assimilated! Clamping resistance is futile…
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 23 Jul 2025, 19:06 Dr Oetiker here…you will assimilated! Clamping resistance is futile…
:lol: :lol: :lol:
Sveedy
Post by Sveedy »
Started back on rebuilding the head for the 850. Thanks to that evil Dr. Oetiker :D , I have some new valves on the way, so my schedule has moved up a bit.
A couple of the other valves also had quite a bit of carbon build up on the stems, so looks more and more like bad stem seals.
1999 V70 GLT
Be careful with those broken valves. I’m not quite sure where the Metallic sodium is but that is not to be played with
I’ve always wondered what exactly happens here. Does a poor seat inhibit heat transfer and the valve metal softens to failure? What causes that gouging, is it hot gas acting like a torch or melting again?
Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 30 times
Post by Chieber »
Gained 10hp with an added spoiler!
At the cost of even more fuel consumption? :D
1/2 a shitbox V70 1998 2.5 NA
DennisCA
Year and Model: 1996 850
Been thanked: 59 times
Post by DennisCA »
I took a pause from the 850 after I did some filler work and I needed to get some supplies too for painting. But tonight I got most of the stuff i needed and I've put a seal coat of 2k epoxy on one fender to start with.
So the idea is to let the epoxy cure, scuff it with P320 perhaps, then go to a high build primer, then metallic base coat, then 2k clear coat.
A lot happening tonight, a person dropped by and sold me these aluminum link arms too
Sveedy
Post by Sveedy »
abscate wrote: 26 Jul 2025, 06:01 I’ve always wondered what exactly happens here. Does a poor seat inhibit heat transfer and the valve metal softens to failure? What causes that gouging, is it hot gas acting like a torch or melting again?
My uneducated guess is that oil seeps down the stem when the engine is not running and sits there. Then when the engine fires up, that oil cooks off, but maybe leaves a little bit of residue. Repeat and repeat, and the build-up must get thick enough to retain the heat till one explosion and it blows that piece out. I'm imagining something like an oxyacetylene torch when you hit the oxygen lever.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Sveedy wrote: 26 Jul 2025, 14:19
It sure looks like result of torch.
I think the sodium is in the stem only.
