M56 noise V70 1998
MotorTheresa
Year and Model: V70 1998 B5252F/S MT
Has thanked: 31 times
Been thanked: 11 times
M56 noise V70 1998
Post by MotorTheresa »
Good morning,
I'd like to hear your 2cts on a supposed transmission noise.
Driving off in 1st gear causes a rattling noise that intensifies going uphill or accelerating.
It stops when the clutch is engaged, comes back when disengaged. It is audible from inside and outside of the vehicle.
Sometimes the noise extends into 2nd gear.
Few things in addition:
Clutch is worn. Does not slip but engages pretty late
Also when backing the car into a parking spot applying brakes and shutting off the engine and then stepping off clutch I hear a clunk. Probably play in the clutch fork.
Any ideas?
Has thanked: 1505 times
Been thanked: 3818 times
It sounds like release bearing noise based on the occurrence pattern
MotorTheresa
I might have used the term "engaged/disengaged" in an unclear manner.
I would point to the clutch thrust bearing as well if the noise occurred when the clutch is pressed.
Noise is there while clutch pedal is released.
MotorTheresa
Could this noise have its cause in a damaged DMF?
How can I check if my vehicle has a dual mass flywheel?
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 89 times
Post by V50M66 »
Sounds like rollover rattle. Common and normal with a single mass flywheel, uncommon with dual mass. If it is dual mass, the two pieces may have seized together, which I have seen before. No real cause for concern.
If your transmission is external slave, it’s single mass. If internal slave, it’s almost always (but not 100% of the time) a dual mass car.
I’d change the fluid anyway if it hadn’t been done recently, as you can learn a lot about the condition of the internals (bearings, synchros, etc) from how the fluid looks
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
2002 S40 1.9T - daily
2004 XC70 - Mystic Silver/Black - former workhorse, parted
2005 V50 T5 M66 FWD - Black Stone/Black leather - former garage queen, sold
MotorTheresa
Will change fluid and feed back findings.
Clutch slave cylinder is external.
Thank you for your answer mate!
rudsaki
Year and Model: 1998 S70 T5
Been thanked: 15 times
Post by rudsaki »
"Clutch is worn. Does not slip but engages pretty late"
I had a new 1999 C70 HT Manual. When i picked it up at the dealer the owner told me the clutch on these engages at the top and quickly after that. He was right. Fast forward I recently bought a 1998 s70 T5 manual with 157k miles and it engages at the top with no slippage.
Btw, my clutch release bearing is going out. Rattles like a diesel when not engaged, quiet when pushed.
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
