Don’t you think you could make a pattern and 3D print some in some sort of…….plastic..?
“You’ll be fine.”
Poor quality valves Topic is solved
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Well after going down many rabbit holes, I have finally figured this all out. I think.
I was mistaken when I assumed that my valves were the stock ones. It turns out that they were replacements, not stock.
The stock ones are embossed with numbers and weigh apx 46g. The smooth ones like I have are the TRW's. They weigh apx 41g.
I am going to go back to the stock ones, and keep the TRW's on the shelf. They apparently are N/A right now.
Moral of the story - Don't use ( or let anyone else use ) aftermarket valve stem seals. I can't explain it, but I've now lived it.
1999 V70 GLT
1999 V70 GLT
- 1471 Views
Last post by GBS
- 532 Views
Last post by Bluevanacd2005
