O2 sensor connection '98 V70 T5
jreed
Has thanked: 352 times
Been thanked: 192 times
Re: O2 sensor connection '98 V70 T5
Post by jreed »
Agreed with the above advice. I used PBlaster and a 22mm O2 socket from Tekton that worked well.
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Post by 5rivers »
I'm in the great north!!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Post by 5rivers »
More questions!
I managed to release the O2 sensor plug from its connection point, but now the issue is getting the sensor off!
None of my 22mm sockets are deep enough to reach the end of the sensor where one would put a 22mm wrench.
I even cut off the wires thinking that would create a little bit more room for the socket, but that did not work either.
I did pick up the O2 sensor removal tool kit from Advance Auto and have heated the exhaust pipe and bung with a newly acquired MAPP torch. I heated up the pipe and bung a few times and applied PB Blaster in between the heat sessions. So far the sensor is not budging!
Any thought on what I might do next? Continue the heat and blaster for another day, maybe?
While I was under the car, I did notice there are two sensors placed on and at the front of the cat; one is on the passenger side half way up the thickness of the cat, the other is on the driver's side but closer to the floor (this sensor is the one I disconnected from the plug-in connection point under the turbo hose). Not sure if I should be removing/replacing the other front of cat sensor (passenger side) as well. Then there is a long wire that travels along the exhaust to about the middle of the car (one would need to remove a rectangular plate that has four bolts holding it up), that I believe is the rear O2 sensor.
My question now, what's the other sensor for that is located in/on the front of the cat (on the passenger side)? I have a '98 V70 5T 2.3L, and pictures I have seen on this site do not reflect the location of these two sensors (on/in the front of the cat) that my car has.
Appreciate your thoughts.
5rivers
jreed
Post by jreed »
I also use P'Blaster and it has worked well for me -- sometimes I also use a torch like what you're describing above. I have heard that a mixture of acetone and ATF is also an effective penetrating fluid -- don't know if it would be more effective than what you've already tried.
5rivers
Post by 5rivers »
I have not tried the acetone/ATF mixture but it's worth a shot! Thanks for the suggestion!
The overspray from the PB Blaster can seems to have covered a good portion of the top of the cat. Is that going to pose any potential fire threats if I use the MAPP torch on the exhaust pipe at the O2 sensor?
Short of continually trying the heat and penetrating oil process, if I put all the turbo/air hoses and wires back together, what would be damaged if I drive the car about 10 miles to a repair shop?
Given that the wires to the O2 sensor have been cut, codes for that will reappear on my code reader, but what might be the consequences of driving it a short distance?
Appreciate your replies/insights!
5rivers
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 130 times
Post by 454cid »
You're not going to do much with penetrant. Remember that seal is designed to hold hot exhaust gas.
Get a long wrench, so you can put more torque on it. Also be prepared to retap the threads.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1505 times
Been thanked: 3818 times
The precat sensor is in the down pipe
The post cat sensor is the one mid-cat
You can drive the car 100s miles without working OXS , they fine tune the mixture for emissions and mileage.
Try the MAPP heating amd cooling cycle several more times, 30 minutes to cool
5rivers
Post by 5rivers »
I did the heat and pb blaster routine again, without success. Although, it did feel like the sensor was beginning to move, but on closer inspection, the points on the hex nut on the sensor were beginning to round off!
Not sure if you can see in the picture, the sensor near the top has some shiny spots on it close to the exhaust, those shiny spots are the corners rounded off. The sensor with the wires attached I am guessing is the downstream sensor.
I'm not sure how to make this picture smaller and less fuzzy, sorry.
5rivers
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Also -> Amazon link
5rivers
Post by 5rivers »
YES, I have been using the shorter one with a clamp around it so the opening would not drift.
5rivers
