Got out my dremel; unfortunately there's not enough room to actually make a decent cut onto the side of the sensor to try to shorten it!
Am trying the acetone/ATF mixture now, I'll wait a few hours and see if the sensor will move using the shortened version of the 22 mm OXS removal tool/socket. I have a hacksaw blade here somewhere!
O2 sensor connection '98 V70 T5
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 14 times
Re: O2 sensor connection '98 V70 T5
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
The home-made mixture(ATF and acetone) to break loose rusted nuts and bolts did not work
I even lathered on brake fluid but, again there was no movement of the OXS.
I have begun to reassemble the turbo hoses, after cleaning the main turbo hose - gosh that was disgusting (inside and out)! And then cleaning out the parts of the turbo where the hoses attach.
Plan on driving the car to a repair garage tomorrow or Friday depending on what's available. Should I be concerned about the remnants of ATF/brake fluid getting too hot/smoking? Should I have a small extinguisher available?
5rivers
- 851 Views
Last post by precopster
- 12 Replies
- 6069 Views
Last post by Rvolvos
