Awesome, thank you! I guess it has been a while.
I did find the source of the coolant leak: An insufficiently tightened coolant temp sensor. Still haven't gotten to it, though.
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 1497 times
- Been thanked: 3809 times
Jet lagged ftom Germany travel
Evita had some serious dirty girl feet from brake dust so I wet them down and I applied some foaming soap , st 0300, listening to the owls. I’ll break out the power washer in the am
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I replaced all seven of the P21W bulbs in the rear of the wagon with new Osram 7506 P21W bulbs ($1.40 each).
Tested the turn signals and parking lights work OK too. Satisfying!
Still need to test that the reverse lights are working OK.
It really makes sense to replace all the tailight and brake lights when one burns out, except for the LED brakelight
- STLV70
- Has thanked: 29 times
- Been thanked: 5 times
I’m replacing the rear shocks, and got quite surprise on the left rear. As I was loosening up the top nut on the shock, there was a “clank” sound on the ground. It appears that a mounting bracket of some top for the rear springs rusted out? The top of the spring and bump stop lodged in the rear wheel. I tried looking at a rear suspension diagram, but am uncertain of what I need to purchase to replace. I have new bump stops, but I’m guessing I need a full refresh?
1998 V70 Base - "Lazarus" - 180XXX
2001 V70XC - "Gustav" - 200XXX
- STLV70
After further searching today, I believe I have an idea what I need to order for the springs. I'm assuming the rusted out chunk is the coil spring spacer? I'll take a look tonight.
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Finally reinstalled the cylinder head on the 850. Just waiting on the coolant pipe gasket, which I thought I had, but apparently I didn't.
I didn't think my lower back could handle leaning in and setting the head in place, so....
1999 V70 GLT
1999 V70 GLT
- Has thanked: 927 times
- Been thanked: 999 times
I like this photo. Massive chain hoist. Under hood bling. Clean engine compartment.
I used the freakishling strong 6 foot college athlete of 180mpounds muscle method
Theres....a left one and a right one and a dual one and a blue one...and a blue one..and a blue one...and they all look just the same....
- A9A0DE32-0B1C-4E7E-8104-3BB974F6136D_4_5005_c.jpeg (44.99 KiB) Viewed 252 times
- F78D64EB-C0BB-4382-8C59-4749A498B6BA_1_105_c.jpeg (177.7 KiB) Viewed 252 times
