Yep - science buff here (family uses Nerd as opposed to buff). Ok the lower hose does get hot and is slightly less warm to the touch as opposed to the upper hose whaicj is what we would expect. HOWEVER, I will check with an infrared temp gun tonight. Both hoses are brand new, same manufacturer. I tested the recirculator and while it was hotter the difference was not huge. Again - will run temperatures tonight and provide actual data.
thanks!!!
Wondering if i have a issue in coolant system
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 47 times
- Been thanked: 43 times
Re: Wondering if i have a issue in coolant system
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Grantkat
Ok, my system is definitely running ok. After commuting, i left the car running, grabbed my temperature gun and digital probe. here are the results:
Temperatures:
Thermostat housing: 203.2
Upper Radiator Hose: 183
Lower Radiator Hose: 158
56 degrees outside during my tests. When parked max heat produced 140 out of the vents. Driving - the temp out of vents varied between lower 130s to 140. Recirculation raised the temp a few degrees but not a huge difference.
Temperatures:
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- 1495 Views
Last post by biohazrd76
- 43 Replies
- 3443 Views
Last post by volvolugnut
