99 s70 hood won't open Topic is solved
cbus
Post by cbus »
under dash lever doesnt pop the trunk - any ideas?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
Did you lift up a bit on the hood and pull out the tongue?
Also -> Amazon link
cbus
Post by cbus »
`99 S70 has the front release under the front edge of the hood.
If you are talking about the hood as in the post title, one of the latches is not releasing because there is not enough upward "tension" when the hood is closed. Pop the release , then go lift up on the hood lightly, then pop the inside latch again and it will release.
The fix is to adjust the offending latch downward about 1/16" using the 3 bolts that attach it to the side of the body panel . This is about a ten minute job.
dosbricks
Post by dosbricks »
I want to apologize to Matthew and cbus for using his user name in the above reply. It was my first attempt at a reply and I didn't know what the heck I was doing.
Ken
matthew1
Site Admin
Post by matthew1 »
It was a touch confusing the first time I read it, but I figured out it must be someone besides cbus.
No worries, dosbricks :).
Also -> Amazon link
