Greetings,
My 1998 S70 recently had service done on it. I've noticed that since then, my low coolant red light come on when I turn on the ignition and it stays on for about 30 seconds. Then it goes off and doesn't come back on.
Should I be worried about this? Can I buy some coolant fairly cheap and fill it up myself just in case? If so, what do you recommend?
Thanks.
Low Coolant Light Comes on Briefly
KBadeau
Hi,
I just had service done to my 1999 S70 and the coolant light started coming on for approx. 30 seconds and then would go off. I added some pemix coolant to the reservoir and it hasn't come back on at all. Hope this helps.
- dosbricks
- Been thanked: 2 times
Possible explanation for the above is that if the shop flushed the cooling system they did not take time to get all the air out. The mix is 50/50 antifreeze and water. Notice there are hot and cold level marks on the reservoir.
- 1349 Views
Last post by balabaika
- 1274 Views
Last post by Steve Ivins
