Ticking is driving me crazy (no pun intended)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I used to have a pretty clicky top-end. New camshafts and I'm assuming cleaning sludge buildup, etc out of the passages in the head and it runs EXTREMELY quiet now - no valve noise at all.
Actually what I would do is an ATF flush - through the engine.
Drain the oil. Fill the motor with 5.5 qts of ATF and let it run for 20-30 minutes. DO NOT DRIVE OR REV THE ENGINE OR YOU COULD DAMAGE THE BEARINGS, but it can idle just fine with no damage. Shut it off and repeat if you want. Then fill it with a good detergent oil (Mobil1 is my favorite). This will pretty much alleviate any oil pressure issues by cleaning all the crud out of the engine - ATF has lots of detergents in it. It's a tried and true old-school mechanics trick.
Piston slap is generally a much deeper noise and less ticky. I've never heard it on a Volvo engine - only the top ends are usually noisy.
4.0 Jeeps and 3.1 and 3.4 liter V6 and lots of V8 GM engines are widely known for this.
Vs starved lifter noise
'98 S70 T5
2016 Chevy Cruze Premier
Volvo4251
Year and Model: 98 S90
Post by Volvo4251 »
The old '98 V70 I had used to tick like crazy from time to time, it was always worse in the winter time. So during the winter months, 10W-40 was put in. The mechanics suggested a thicker viscosity not only for the winter season, but for the ticking as well. It definitely helped, although it still would tick from time to time. It's just one of those things that happens on a 5 cyl. Volvo... and moreover older 5 cyl. Volvo's as well.
Drive Safely.
2007 Volvo XC70 Adventure Series
1998 Volvo S90
Previous Volvos:
96 Volvo 850 Platinum
11 Volvo C30 T5
07 Volvo XC90 3.2 AWD
98 Volvo V70 2.5 SE
95 Volvo 850 Turbo
94 Volvo 850
91 Volvo 240 Wagon
90 Volvo 240
89 Volvo 740 GL
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Well, brilliant idea I have had the lifter noise for(probably forever) but more so in the winter. I'm going to try and run some ATF before I run new oil... How'd it work out for you? nothing at all now?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
