Correct thermostat temp for 95 850 N/A?
wheelsup
Has thanked: 15 times
Been thanked: 20 times
Post by wheelsup »
FCP lists the 92 as the OEM for the non-turbos but I replaced mine and it makes the temp sit "just" above 3 o-clock by a mm or so. Thoughts? I can't find a definitive answer.
Is the 92 the correct one for a 95 850 N/A?
-matt
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Vadis calls the N/A out as a 90°. I really don't think it much matters, the temp ratings are the point where the thermostat starts to open and the ultimate operating temperature is much higher than 90° or 92°.
wheelsup
Post by wheelsup »
Thank you I was looking some hard info from Volvo, I agree though 2C is very little, my guess is we are marking with a pencil cutting with an axe so to speak.
I'm replacing the ECT as well, and am replacing the radiator hoses, I will order a 90C one just to make me feel better and help me sleep at night :).
I searched several forums and I couldn't find it, I posted a response to my own question over at volvoforums.com as well so anyone searching (like me) can now find it.
Thanks again Ozark.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
...FCP lists the 92 as the OEM for the non-turbos...
I dont think thats correct, 90 is the only one you can get from dealer these days.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
Larmor
Year and Model: '93 850, manual
Post by Larmor »
I think it may be a typo on FCP's part. The exact same item number, Wahler 271664, is listed as 92 °C at FCP and 90 °C at eEuroparts.
wheelsup
Post by wheelsup »
OK to wrap this up I replaced all the hoses besides the lower radiator hose (that was done 2 months ago when it blew), the thermostat, and the ECT sensor.
The hoses I had were cold and didn't like to go on, I simply but them in hot water to warm them up, that helped a lot. Also I reused most of the clamps. I couldn't get the clamps onto the new hose that connects the thermostat housing to the reservoir (small hose) so I used cheapies I had laying around. One broke but fortunately is tight, I figure I won't ever have to replace the hose again so oh well.
The ECT sensor was a BITCH to get out, I had to go buy a 19 mm spanner from autozone, I still don't think I got it tight enough because the edge of the wrench rubs against the intake manifold but so far no leaks so I guess I did good. I guess that's why it has a crush washer on it.
No codes or anything, temp came up nicely and looks to sit a bit lower, as I believe I had a 92C in there before but didn't have it written on it.
Oh I also bought the new theromostat housing bolts from the dealer, $0.81 for both out the door, WORTH EVERY PENNY, they are made quite a bit stronger made out of a blackish metal. I also put antiseize on them.
Took me about 3 hours, no I'm no mechanic... :D
