Ball joint/control arm survey
Ball Joint / Control Arm Survey
I would like to hear everyone's experiences with different brand control arms/ball joints. I am faced with replacing mine for the third time since I have owned the car and it will be at least the fourth time in the car's life. I bought the car with 107,000 miles on it and replaced the ball joints not too long after that. The original ball joints had already been replaced at least once with aftermarket. The car now has about 178,000 on it. I have tried ScanTech (before I knew anything about them) and then the Uro brand. Others I know of are OEM (don't know the manufacturer), Beck/Arnley, Febi. Probably others. Lets hear it!!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
JRL
- Year and Model: Several
- Been thanked: 16 times
Use VOLVO OEM parts for this, the best out there.
Most suspension parts (except actual shock and springs) that you should install should be OEM Volvo, still the best available and will last the longest!
- Has thanked: 17 times
- Been thanked: 35 times
JRL speaks the truth- all other brands are junk and you'll be redoing the work within a year again (no lie).
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I agree w/ JRL and MIJ, OEM is the only way to go on this.
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
What's the std failure mode of the OEM control arm? Mine was OEM volvo, and the ball joint was completely shot. The bushings, on the other hand, looked fine. If the ball joint is the common 1st failure point, perhaps it'd be worth looking into a repair method to allow replacement of the outer joint only. It seems a shame to toss out the whole assembly when it's only that outer joint that needs replacing.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
Mine went through two sets of OEM ball joints in about 120,000 miles. The second time was definitely the ball joint and not the bushings. I have had aftermarket control arms go through the bushings before the ball joint though it seemed close. I think the moral of the story is, the control arm design standards are poor.
2004 XC70
renns
I just finished installing one of the cheapee FCP control arms a couple weeks back. Unfortunately, FCP only stocks the $38 and $145 versions, and in a moment of weakness I went down the low road. It'd be nice if there were a mid-range option to choose from. Another on-line place I found lists four different versions in order from cheapest to most expensive: ScanTech, URO, Bilstein/Febi, Lemforder. Any feedback on these different brands?turbotim2 wrote:Mine went through two sets of OEM ball joints in about 120,000 miles. The second time was definitely the ball joint and not the bushings. I have had aftermarket control arms go through the bushings before the ball joint though it seemed close. I think the moral of the story is, the control arm design standards are poor.
confused_al
- Year and Model: 1996 TLA wagon
My original control arms lasted 160k/14years (a huge pothole killed pass side one last winter).
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
mdempst_79
- Year and Model: 2006,2007 XC90
I went with the Uro Parts control arms on my V70, and they lasted roughly 6 months before the balljoint boot rubbers started rotting, and then water took over killing the joint. Went and bought Volvo OEM arms, and I have not looked back.. 9 months later they still look like brand new.
Dont cheap out unless you are okay doing them again in less than a year. You get what you pay for with this kind of stuff.
Mark
Mark
2007 XC90 V8 Sport 265,000km
1994 850 Turbo Auto 365,000km (R.I.P - 2005-2017)
2006 Ford F350 Super Duty 4x4 Diesel
1999 Landrover Discovery II 259,000km
1992 Range Rover Classic 3.9 250,000km (In restoration)
- 4712 Views
Last post by oragex
- 15 Replies
- 3725 Views
- 4148 Views
Last post by Tonyx
- 12 Replies
- 5604 Views
Last post by darrylrobert
- 7183 Views
Last post by BrianV70
