IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
PVC system
Volgrrr
Year and Model: '95 T5 wagon
PVC system
Post by Volgrrr »
My '95 T5 has developed a distinct, annoying hesitation when the accelerator is depressed firmly. It then recovers and runs smoothly. Also when the accelerator is released, the engine seems to nearly cut out.
Also, when the vehicle first moves off, the instantaneous fuel consumption on the computer indicates the engine is using about 50 litres/100 kilometres and then when normal road speed is reached (i.e. 100 k.p.h) the consumption gradually drops down to about 25 litres/100 kilometres.
Then, after about 5-10 minutes the fuel consumption continues to drop until the vehicle is only consuming in the region of 7.8/8.3/100 kilometres and, over a full tank, averages about 9 litres/100 kilometres which, in my opinion, is quite acceptable.
Has anyone got any ideas what causes the initial atrocious fuel consumption in the first few minutes of operation? I wouldn't like to only drive about 15 kilometres per trip on a fairly constant basis because I would never be able to afford the fuel (luckily it does get better).
Beside the above fuel consumption the engine also hesitates quite noticeably on initial acceleration and does the same thing on deceleration.
My guess is the hesitation problem might be fuel related due to some item(s) that affect/control fuel supply not operating properly - but which one(s) and where?
Does anyone out there have any idea(s) what might be causing this irritating problem?
There are only two types of car owners - those who own Volvos and those who wish they did.
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Re: PVC system
Post by 9394volvo850s »
you might want to do a tune up if its been a while. and also a fuel system cleaning with throttle body and air intake cleaner cant hurt. also pull the dipstick out check to see if you have smoke coming out of it at idle. if so the pcv may be cloged too.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
Volgrrr
Re: PVC system
Post by Volgrrr »
I'm trying to systematically go through the various items that might possibly cause a fuel rich situation at acceleration and deceleration.
So far I've cleaned the MAF sensor and the injectors and changed the air cleaner.
The next thing I'm going to tackle is to thoroughly clean the throttle body to see if that makes any difference.
However, I've been wondering what symptom(s) a partially or fully blocked PVC system might show as well as what effect it might have on fuel consumption (hence the heading of the original post - even though I was side-tracked while writing the post and made no mention of it at all).
Also there is absolutely no sign of the sump being pressurised and the vehicle uses basically no oil between services.
So I guess it is just a matter of trial and error until I eventually find what is causing the problem or throw my hands up in despair.
valvster
Year and Model: 850 1996
Re: PVC system
Post by valvster »
I'm thinking thermostat & coolant temperature sensor.
cheers...Valvster
phils94850
Year and Model: 2009 s60 turbo
Re: PVC system
Post by phils94850 »
valvster... as posted, when was the last time you did a good tune-up on the car. Start off with the basics, and work your way on..
1996 Platinum Edition
Volgrrr
Re: PVC system
Post by Volgrrr »
Thanks for all the help so far - I appreciate it very much. The vehicle is due for its next service in about 300 kilometres (180 miles) and I will ask the garage to give it a full tune-up then.
Yes, I agree a faulty coolant temperature sensor would fit the bill (i.e. signalling the EMS the engine is still cold when it really is at normal operating temperature - initiating the EMS to respond by increasing the richness of the air to fuel mixture) however the temperature gauge in the cabin moves up to the 3 o'clock position and stays there without any variation once the engine is warmed up.
So, is it possible the cabin temperature gauge will indicate the engine is operating at normal temperature if the coolant temperature sensor is actually faulty?
