Volvo 850 Turbo 1995 - Replacing Windshield Washer Reservoir
I have a Volvo 850 Turbo, 1995, that has never given me any problems. My windshield washer reservoir has a leak. I know this because I pour in fluid and it begins to slowly drain out. I just purchased a replacement reservoir for it but have no idea on what I need to do to replace it. Do I have to take off the tire or is there a more simple way?
volvomileage
- Year and Model:
hello welcome to mvs
the reservoir is located on the front passenger side of the car near the front bumper. its underneath
you can easily located it from the filler neck, its held underneath by 3 bolts.
you have to unplug the connectors from the windshield washer motor and fluid level indicator from the top...the unplug the main hose that comes from the ww motor..
from underneath its pretty forward remove the 3 bolts theres one in front, one on the side near the engine and one in the back near the wheel well...there is a gasket between the container and the cars metal frame remove it to use it again...installation is reverse on removal
best of luck
best of luck
volvo 850 95 sedan non/turbo 185 k
volvomileage
- Year and Model:
here is a diagram
cheers !
cheers !
ww.doc- (213 KiB) Downloaded 3439 times
- 1822 Views
Last post by viper69
- 36 Replies
- 25026 Views
Last post by StickyPocket
- 4492 Views
Last post by eyerollXC70
- 7524 Views
Last post by jadnhm
- 1572 Views
Last post by Roger_850T
