IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Part 2: PNP Removal
Year and Model: 850, S/V70, 06 S60R
Has thanked: 112 times
Been thanked: 327 times
Re: Part 2: PNP Removal
Post by erikv11 »
1) inside the car
2) yes
This step is in "alignment and reinstallation," but it can be made trivially easy by a little prep at the beginning, during disassembly. The adjustment is all achieved via the two outer bolts. As suggested elsewhere in this thread, before you start use a Sharpie and draw on the PNP body a nice tight outline around the hex heads. When you reassemble, put the outlines back under the hex bolts, then tighten it up. This way, you get the factory placement every time. I've done three switches this way, never had to give adjustment any thought at all. Just bolt them back up, they work as they should.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
gone: '96 NA 850 210k, '98 NA V70 182k
polskamafia mjl
Has thanked: 10 times
Been thanked: 9 times
Post by polskamafia mjl »
erikv11 wrote: 2) yes
Technically no, according to this write up you begin with the gear selector in Park.
jrobles007
Year and Model: 850 NA, 1994
Post by jrobles007 »
Great write up thank you very much! I was able to rebuild my switch by starting and ending in neutral. This took care of my flashing arrow. Sharpie marking helped out.
JR
polskamafia mjl
Thanks for the comment, JR. Glad it helped.
Natural Bite
Year and Model: 1997 850 T5
Post by Natural Bite »
I have read this forum and replaced the PNP switch today. All went well until I reconnected the battery, I had everything aligned as it came out with the clean bolt spots covered. I opened the door and the emergency flashers started flashing, I turned the key on to start the motor, nothing but all lights in the dash came on, I was able to shift the shifter to reverse, got back up lights, got all gears as I moved the shifter. Would not try to start at all. I went back in and adjusted the switch and cable position, no luck to start the motor, still had back up lights. I pulled it all back out, checked the switch, ( used ) check the old switch, cleaned it put it back in, still flashes back on, lights in the dash and no ranking in park or neutral. Puzzled to what I have done now, Any Ideas?
FLXC90
Year and Model: 98 V70 T5
Been thanked: 35 times
Post by FLXC90 »
You may have tripped your alarm. Lock and then unlock your door with the key, see if that helps.
Current Volvos:
polskamafia mjl
+1
Flashers going off and no start usually points to the alarm/immobilizer.
dcaplan
Year and Model: 850 - 1997
Post by dcaplan »
I had the flashing arrow but otherwise no other symptoms of a faulty PNP. Decided to take it out and clean it for the heck of it. I cleaned it up, filed the contacts and greased it. After i re-installed it, im back where i started. Everything works fine, including being able to start in neutral but i STILL have the light. Anyone have a possible explanation for this light?
Thanks!
Year and Model: Many Volvos
Been thanked: 56 times
Post by Ozark Lee »
dcaplan wrote:I had the flashing arrow but otherwise no other symptoms of a faulty PNP. Decided to take it out and clean it for the heck of it. I cleaned it up, filed the contacts and greased it. After i re-installed it, im back where i started. Everything works fine, including being able to start in neutral but i STILL have the light. Anyone have a possible explanation for this light?
Thanks!
Is the CEL on as well and have you read the codes?
dcaplan
Post by dcaplan »
Thanks!
No check engine light and my code reader is coming in the mail, any possible explanations with this info?
Thank you!
