Background (time-line of events):
-Had code for Cat Converter (P0422).
-Had original O2 sensors @ 142K.
-MPG is fine.
-No H02 sensor codes.
-Replaced both 02 sensors (OEM front, aftermarket rear).
-Many 100s+ miles later, get P1132 (front O2 sensor problem) + NO difference in driving.
-I checked the connection, and found I hadn't secured it in perfectly. Took apart and re-did it correctly.
-Reset code, drove approx. 1500 miles until now it's back (P1132) + still NO driving issues + MPG is still fine.
-Haven't had Cat Converter code reappear.
I'm getting a bit annoyed by this. The car runs very well, and as far as I know if the front O2 was really bad it would cause bad performance + low mileage. The light has come on in both instances during normal driving, and nothing changed when it illuminated. I know the connection is secured this time.
Any ideas?
