hi all
96 volvo 850 turbo wagon
Alright here is the problem. my wagon is giving and intermittent, erratic idle and is giving me around 10 mpg. i found a crack in the hose on the driver side vacuum hose on the intake manifold as well as a crack in the hose on the bottom of the throttle body so fixed those with no avail. while sitting the car smells a little more sulfur like than plain rich. i changed my plugs which were built up with carbon and i also removed my idle air control and cleaned it well and also removed and cleaned my throttle position sensor. it will run fairly smooth, then i detect a slight miss, then goes to 400rpm bucking idle then back to smooth all while sitting at a light for 2 minutes. i check for codes everytime i drive it just to see if its throwing a code and always 0 codes. any ideas would be great
thanks
Adam T
erratic idle, sometimes
- Year and Model: Many Volvos
- Been thanked: 76 times
Without any codes this is a tough one to solve. Obviously something is wrong and everything in your symptom description points to a vacuum leak but that normally throws a CEL every time.
If it would finally throw a CEL and you could post the number back we might be able to help.
We aren't ignoring your posts but we just don't have enough information to post an intelligent response.
landyacht33
- Year and Model:
i agree! i took it to the dealer and they claimed they couldnt find anything wrong with it. i drove it around some again today and it is idling terrible but only at a stop. i got it to even idle around 200 rpm and the lights went dim but couldnt get it to actually stall. DRATS!
still no codes and i dont want to throw money at parts. can a bad cat cause all this? the car smells a little more sulfur like then just the typical rich and it doesnt smoke a whole bunch. ??????
jerk wagon!
HAPPY NEW YEAR!
jerk wagon!
HAPPY NEW YEAR!
850doin150
- Year and Model: 96 850 turbo wagon
I have the same exact problem. Except mine is throwing the service light!
So maybe it will help solve yours. I gotta go to autozone n see what the code is and repost.
Same smell also!
Same smell also!
landyacht33
- Year and Model:
the service light is just a reminder for service and not a signal of a problem. i have a few ideas such as coolant temp sensor and fuel pressure regulator. ill let you know as well when i figure this out.
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Did you ever figure this problem out? I have the same problem with the idle bouncing up and down in park.neutral when I rev idle. My service light goes on when I first start her and stays on extra longer than other lights. I just installed new MAF, temp sensor, plugs, wires, cap/rotor, oil/filter. It feels like a fuel problem to me; fuel injectors are good, fuel pump is good, new fuel filter. I was thinking fuel pressure regulator myself and seeing you mention it in your thread has me leaning towards that. There are no loose or missing vacuum hoses and what I noticed is this starts to happen after she starts to warm up near operating temperature. Appreciate any info on what you did.landyacht33 wrote:the service light is just a reminder for service and not a signal of a problem. i have a few ideas such as coolant temp sensor and fuel pressure regulator. ill let you know as well when i figure this out.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The service light means nothing. It was put there to remind you to bring your car into the dealer for service. Ignore it, put a piece of tape over it, or remove it.
This is a long shot towards the erratic idle, BUT
Switch your O2 sensors and connectors. The front one probably won't reach the rear connection, but that is OK - just leave it unplugged, but put the sensor in place so it doesn't sound like a B52.
With the rear sensor up front, does the car run any better once it warms up? The sensors work off an oscillating pattern, and when one goes bad, it can do exactly that with the idle.
'98 S70 T5
2016 Chevy Cruze Premier
- shiloh51933
Yes the service light is annoying, lol...I guess your thinking that the front one is on the way out. This sucks cause this is all happening at once...the MAF had to be replaced cause she wouldn't start without it and I'm not the type to ride around without the MAF or an O2 sensor unplugged(I see hacks do it all the time round here). Good look on the response my dude.jblackburn wrote:The service light means nothing. It was put there to remind you to bring your car into the dealer for service. Ignore it, put a piece of tape over it, or remove it.
jblackburn
Give it a shot - you don't want to throw $100 at a part you don't need. The rear one doesn't do anything but monitor the efficiency of the catalytic converter, so you will throw a code but it won't do anything in the meantime.
'98 S70 T5
- 565 Views
- 3448 Views
Last post by precopster
- 1434 Views
Last post by metalriff
- 1031 Views
Last post by saulgar1
- 1686 Views
Last post by mattmatt
