Suggested maintenance for thrashing
s70glt novice[Will]
Year and Model: s70 glt 98
Post by s70glt novice[Will] »
Hello, I have a 98 s70 GLT, i have completed stage 0 and have ordered a 16t and ARD Green tune (17 psi).
Being a teenager, I will of course keep my foot down. I realize how much wear and tear this causes and want to know things I can do to keep up with it. I want to keep this car for a long time, preferably until it is regarded as a classic. (Loooooooonnnnnnnnnngggggggggggggggggggg time) so of course i need it to avoid bad things.
What are some steps i can take to prevent wearing out my engine? I mean in addition to regular maintenance and such.
I already plan to do seafoam on every oil change, could this back fire(seals and such)?
Thank you!
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Regular maintenance is really all you need to do. Some people change oil a little more often, some use synthetic (I do). A oil cooler and tranny cooler would be 2 real good things to do if you plan to keep your foot in it. I would NOT suggest seafoaming the car that often. Probably every 50,000 on a well maintained car is plenty. Seafoam treatment is usually for cars that have had poor maintenance history. Keep your PCV system serviced, boosting often puts a strain on that system.
Also, you may want to keep some extra money around for tickets. The public service team is out in strong numbers these days. A good radar detector will help but the last time I got a ticket radar wasn't even used.
s70glt novice[Will]
Thank you. I have yet to do PCV but its not bad, you have to concentrate to see the smoke. I'll do some research on the tranny and oil coolers. No on the seafoam, thank you. i live in an area where cops do not care so much about speeding, i have never gotten a ticket and believe me, i should have. I also dont do it often enough to warrant buying a system like that. thanks for the advice!
'98 s70 GLT-127k
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If you have to concentrate to see any smoke you need to do it ASAP
You should NOT see any smoke at any time
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Its an interesting topic: the proverbial "little old lady's" car that only gets driven to church on Sunday is found and in miraculous shape after decades.
The reason for that is because "thrashing" a car puts wear and tear on it. Not just the engine, but everything. HArd accelerations, aggressive turns, rapid braking. These all exert large forces on the chassis and suspension of the car. Stomping the gas at a green light puts all that torque into pushing the car forward, the whole suspension feels that force.
Its more than engine and transmission. The bushings and bearings of the suspension feel it too.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I'd worry the most about your transmission with that kind of abuse.
'98 S70 T5
2016 Chevy Cruze Premier
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Swepco Engine Oil and Transmission Fluid.
http://www.paragon-products.com/Swepco_ ... /sw306.htm
http://www.swepcousa.com/lubesite/lubeprod.htm
These are standard fare with Porsche and Ferrari people. Was told UPS, United and Chevron use their lubricants. Friend told me Swepco Transmission fluid is in Factory Porsche's according to Andial
http://www.andial.com/about.html.
s70glt novice[Will]
right, thanks for the info! and i wont be doing many off-the-line things. mainly highway. i will be doing the suspension in the next few years. in the meantime, i think the PCV is the next major issue
'98 s70 GLT-127k
D_V_ENT850R
Year and Model: 850R 1996
Post by D_V_ENT850R »
PCV isn't too bad! Just a thought for you, if you decide on a catch can make sure the hoses are the big enough diameter! I put one in mine and the hoses and fittings were to small. Effect was every time I would lift off the throttle fast after boosting it would smoke bad! Bigger hoses and fittings it's ok!
s70glt novice[Will]
Alright, thanks for the tip. Unfortunately i have a cyl 5 misfire, and its noticable. so im solving that, and any other issue before installing the tune and turbo. thank you!
'98 s70 GLT-127k
