Intermittent speedometer
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
My speedometer only operates intermittently. I have tried to note any order to external factors such as temperature, but there does not seem to be any order.
I know about the odometer gear, but can't see a mechanical failure being intermittent.
I rarely use cruise control, so it took me a while to notice this. Today I tried to switch on the cruise while the speedometer was not working, I got no response. It is my general impression that cruise control does not get its signal from the speedometer.
Can anyone tell me the points of commonality between the cruise and the speedometer?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
JDS60R
Been thanked: 3 times
Post by JDS60R »
Vehicle speed sensor
Retired
c70_lindsay
Year and Model: 99 S70 T5.
Post by c70_lindsay »
From what I've been told by others on the site(see my posts) sounds like a abs module.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
I concur, ABS module.
(On 1996-1998 models, the vehicle speed is measured through the ABS module from the two front wheel sensors).
'98 S70 T5
2016 Chevy Cruze Premier
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Possible speed sensor, but unlikely. Speedometer and cruise run off of the abs module.
Are your abs lights on?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Faust
Post by Faust »
No, but I had to change an axle recently. I think I had better pull the wheel and checkthe ABS sensor.
2004 V70
Matty Moo
Has thanked: 1 time
Post by Matty Moo »
Do your ABS lights come on at start up like they're supposed to? Seems odd that it isn't working yet you don't have a light.
One of three possible things...could be more though.
1. Speed sensor isn't plugged back in properly.
2. Axle wasn't torqued down properly
3. This just happened to be the time your abs module went out
2000 s70 GLT
2014 Ram
