I've been a Mobile-1 guy for as long as I've been around these cars. It has less to do with science than with just knowing your putting the best stuff possible in your car.
The other day I discovered that Redline makes motor oil and it's better than what I've been using. I have never liked extending Oil Change intervals past 3k regardless of my oil quality. If I'm going to change at 3k anyway, would Redline offer me any benefit over Mobil-1, however slight?
Question for Oil Experts
JRL
- Year and Model: Several
- Been thanked: 16 times
If you're using and changing synthetic at 3K miles it won't make a darn difference, your engine should be sparkling clean inside
and it's Mobil 1, not MobilE 1 (FYI).
Even I don't change it that often, I do a 4-4500 mile oil change with Mobil 1 on my cars
precopster
- Year and Model: Lots
- Been thanked: 128 times
There is some very compelling data regarding Redline and its ability to prevent engine wear. It costs significantly more than other oils but tests are showing that metals left behind in this oil even after extended periods of use are far less than other oils including full synthetic.
Of course you had better do the research yourself but everything I've seen so far about Redline is very positive.
Imagine changing oil only every 3 years or so!! I could go on holidays with the accumulated time saved.
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
I've never heard of anyone having a oil related failure if they're using a high quality synthetic, keep it topped off and change it regularly. You can switch to red line but in the big scheme of things, does it really make any difference? It sound like you're already doing everything right.
I use 5w40 diesel synthetic (Rotella, Mobil, Delo... whatever is on sale) once a year, regardless of mileage.
Ambitious but rubbish
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
The 3k change interval is left over from the 1950's when it was necessary. But oils and engines have improved dramatically since then. It used to be that an engine with 100,000 miles on it was worn out, but today that's nothing. Harder materials, tighter tolerances, better alloys, better design, and better oils have made engines the most durable part of cars. When was the last time you actually saw a modern engine that was worn out when it had even minimal care? Today the rest of the car is what limits the car's life, not the engine.
Slavishness to 3k oil changes today is not necessary, in my opinion.. Spending even MORE money on better oil than Mobil 1 with such short change intervals is borderline obsessive compulsive. Again, just my opinion, do what you want - but you could run any old dino oil in your engine with 3k oil changes.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I have a GMC Truck, 2003, little V6 that's used mainly around town with a once a month highway run. I use Mobil-1 0W30 in it and change at 7500 or once a year. This truck's engine still runs as good as the day I bought it with 28,000 and now at 190,000. I've decided to go to M1 in my 98 V70 with the same 7500 mile change schedule after changing the first time at 5K.
Synth oil seems to last forever. And yes, I do use it again in my yard equipment. I even used the old oil as chain lube on the chain saw, messy as hell and frequent refills but it works.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
6-7500 change intervals for me. Still looks brand new at 3000 (usually have to add a 1/2 a quart then).
'98 S70 T5
2016 Chevy Cruze Premier
- instarx
LOL. That was a good idea. Why didn't I think of that?jimmy57 wrote:Can I come get that 3000 mile used oil from you? I'd run it another 5K in my cars. Then I'd drain and run it in my lawn mowers.....
2011 XC60 - sold
2011 XC60 - sold
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
AT 3,000 miles any of the good quality name brands should do especially:
CAN SYNTHETICS EXTEND DRAIN INTERVALS?
http://www.swepcousa.com/lubesite/tt899.htm
Lab Analysis
http://www.swepcousa.com/lubesite/loa.htm
Lubricant Certification/Approval Process
http://www.swepcousa.com/lubesite/lubepdf/TG_200203.pdf
Meet Volvo & Mercedes Heavy Equipment Specs
http://www.swepcousa.com/lubesite/lubepdf/TG_200301.pdf
Page 2 is link but read page 1 also about Swepco 306 Motor Oil pertaining to what the Builders have to say.
http://www.clubtitan.org/forums/showthr ... 584&page=2
Excerpt: "I've always used SWEPCO 201 in the gearbox and haven't had any noticeable degradation in 17 years of ownership. I've heard that SWEPCO is gentle to the synchros compared to most petroleum based lubricants. . I hope links are allowed here: 201 Gear Lube "
Myself I have been using 714 20W transmission oil since 1998 and engine oil earlier.
Independent Volvo uses the majority of it's products. I use to change at 7.5K in the early day but changed to once a year.
http://www.yelp.com/biz/independent-vol ... lnut-creek
For Transmission Oil Discussion
https://www.matthewsvolvosite.com/forums ... =1&t=47877
BUT...tjts1 wrote:I've never heard of anyone having a oil related failure if they're using a high quality synthetic, keep it topped off and change it regularly. You can switch to red line but in the big scheme of things, does it really make any difference? It sound like you're already doing everything right.
Lab Analysis
- 631 Views
Last post by cn90
- 32 Replies
- 774 Views
Last post by Twarr12000
