1999 S70 One of these head bolts is not like the others.
- E Showell
- Year and Model: V70R '06 AWD Auto
- Has thanked: 35 times
- Been thanked: 88 times
Re: 1999 S70 One of these head bolts is not like the other
There are those on here who believe in "waking up" the head bolts with a hammer blow or two before loosening. Some swear by impact wrenches for removing them. I think luck has a bit to do with it as well. Although I haven't tested the theory, running the engine to heat things up a bit before attempting removal might work. Trouble is, usually, the reason you're removing the head bolts is that the engine won't run . . .
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'95 855 auto (sold)
- Year and Model: 850 '96, S70 '99
That occurred to me ... after it broke. It helps shatter any corrosion cement.E Showell wrote:There are those on here who believe in "waking up" the head bolts with a hammer blow or two before loosening.
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 458 times
- Been thanked: 1367 times
So you have a stuck piece in the block below the head?
Link To Volvo Glossary
Success! After soaking a week in Liquid Wrench. I covered the top of the block with Vaseline and Saran Wrap to keep any chips from going any undesirable places. I started with a forward 1/8" cobalt drill bit (with a homemade bushing made out of glued together #8 steel flat washers to keep the bit centered). As the bit started to bite I felt the bolt come loose. I suspected a forward drilling would unwind any residual tension in the threads. I then switched to a 3/16 reverse drill bit and the bolt screwed right out. Took all of about 5 minutes. Took me longer to get the tools out. I stuck a magnet down in the hole a number of times to remove any leftover chips.
- E Showell
Bravo Zulu
'95 855 auto (sold)
'95 855 auto (sold)
- Year and Model: 850 glt turbo 1997
This thread saved my life!!! It work just as you guys described, thank you so much.
