Did you know? 🤔
Very rough start and lots of white smoke comes out. Topic is solved
Has thanked: 272 times
Been thanked: 849 times
Trinidad & Tobago
Re: Very rough start and lots of white smoke comes out.
Post by abscate » Sat Aug 13, 2016 5:41 pm
Keep at it. Sooner or Later it will yield...
Link To Volvo Glossary
jking4020
Year and Model: 1997 850, 2001 v70xc
Has thanked: 0
Been thanked: 0
United States of America
jking4020
Post by jking4020 » Sat Aug 13, 2016 6:54 pm
Can you please explain the "ram tube in" cleaning method?
Trinidad & Tobago
Post by abscate » Sun Aug 14, 2016 5:49 am
There is a port that runs up a casting in the block that plugs with sludge in a neglected engine. By ramming a piece of tubing into the port, you remove the sludge about a cm at a time , pull the hose out, either clip it or blow the sludge out , and repeat
There is a nice set of pictures in one of the PCV threads.
Has thanked: 80 times
Been thanked: 243 times
Post by erikv11 » Sun Aug 14, 2016 7:22 am
If the blockage is all hardened (very common) you will need something much harder than tubing, like a screwdriver or drill bit, to clean out the port. You really want to get the hole completely free of debris.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 165k
'99 Camry V6 :shock: 125k
jking4020
Has thanked: 0
Been thanked: 0
jking4020
Post by jking4020 » Sun Aug 14, 2016 11:38 am
I just put a long zip tie down the lower port and it went most of the way in. Like 6" or so. Both ports on block are free of clogs. Where in the hell would the crank case still be plugged? Pan removal?
beigg
Year and Model: 850 97
Has thanked: 0
Been thanked: 0
Uruguay
beigg
Post by beigg » Sun Aug 14, 2016 12:41 pm
Valve seals have to be allowing the oil to billow out.
ugh smh 850 Turbo fridge
jking4020
Has thanked: 0
Been thanked: 0
jking4020
Post by jking4020 » Sun Aug 14, 2016 10:22 pm
It's gotta be that. I re did the whole pcv today. Replaced vacuumed lines. Did 5/8" heater hose replacement on main return line. Put seafoam in where was instructed.Thanx for all replies and help. I learned a lot about my engine in all this. I'll keep up to date on how this all turns out.
Post by erikv11 » Sun Aug 14, 2016 11:31 pm
Also make sure the hoses are not reversed on top of the oil trap. The one at the back left goes to the top of the head.
'96 855 NA, 145k
'06 S60 R, 165k
jking4020
Has thanked: 0
Been thanked: 0
jking4020
Post by jking4020 » Sun Aug 21, 2016 11:55 am
I yield. Can't figure out where the excess pressure is coming from. Im gonna get new maf sensor. I so appreciate all the help. Love this site.
