Did you know? 🤔
Third brake light not working. Can it be fuse?
lext
Year and Model: 1994 854
Has thanked: 1 time
Been thanked: 0
United States of America
lext
Post by lext » Fri Apr 29, 2016 3:59 pm
The third brake light (the one on top of the rear seat) in my car has not been working for as long as I can remember. As a result the "bulb out" idiot light always turns on whenever I brake. Once some years ago I did try to look at it, but all I got was that there was no voltage out to where the brake light was (when brake pedal was pressed). I didn't know what else to do (all the wires look hidden to me) so I just left it that way. I've always wanted to go back some day though (I'd rather no warning light being on while I drive :) )
One thing I've often heard about is check the fuse. I guess that means the fuse box in the engine bay near the driver side? But if the other 2 brake lights still work, that cannot be the fuse, right? Or is there separate fuse for each brake light? I've been looking for a fuse diagram for 850 but only found this, which is for a 1998 V70: http://matthewsvolvosite.com/forums/dow ... 920b6401a8. As far as I can tell there is only one fuse for the brake lights in that fuse box, but I don't know if there are other fuse box location that is only mentioned in the "user manual", which I don't have.
Thanks.
94 850 non-turbo
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 22 times
crlande
Re: Third brake light not working. Can it be fuse?
Post by crlande » Fri Apr 29, 2016 5:01 pm
Simple stuff first. Get into third brake cover and make sure bulb is good. The cover has two push tabs on side of it. While in there to check bulb, look at wire contacts and clean.
MadeInJapan
Has thanked: 7 times
Been thanked: 20 times
MadeInJapan
Post by MadeInJapan » Fri Apr 29, 2016 5:49 pm
We had one on a '94 850 as well that was not working most of the time...as crlande said pull it off and check the bulb. Our bulb checked out...imagine that, but a new bulb fixed the problem.
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 52 times
Been thanked: 31 times
Norway
Sommerfeldt
Post by Sommerfeldt » Sat Apr 30, 2016 6:04 am
Well... I suppose you checked the bulb when you put in the effort to check for voltage... if you didn't, then check it. There's no separate fuse for the brake lights, so the next step is to go over the wiring. You can reach most of the wiring by taking off a few interior panels - nothing major. Start at the light, make sure it's whole and connected, and go from there.
Btw, there's supposed to be (I think) 2 spring connectors on that thing, which can become corroded. Slide the assembly off and check those first.
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
