I'll be performing maintenance on the server March 31. I'll try my best to make interruptions as painless as possible. Thanks for your understanding.
Did you know? 🤔
98 S70, N/A Control Arm (Ball Joint) installation question
chrafael
Year and Model: 1998 v70 GLT
Has thanked: 0
United States of America
chrafael
Re: 98 S70, N/A Control Arm (Ball Joint) installation question
Post by chrafael » Tue Aug 02, 2016 6:15 pm
Abscate is right. This is classic toe out problem. Safe bet your mechanic tried to string line the front and rear wheels not realizing the rear is a fraction of an inch narrower. This leads to what you see. I would be more concerned about any possible slack in the pinch bolts/spindle ears. If it wallows out too much it may pull through. At the very least recheck your torque on the bolts. It may surprise you.
Roger_850T
Year and Model: 854T 1995
Has thanked: 0
Been thanked: 13 times
Roger_850T
Post by Roger_850T » Tue Aug 02, 2016 6:59 pm
I agree...
1. Your ball joints look correct. I looked at the amount of stem protruding from the top. I am used to them being fully seated at this point though, so I'm not sure how you could have got them in any more. However, the groove in the stem will interlock with the bolt when installed, so it's either correct, or it's out 1/2" or so, which yours clearly is not, so I think you're fine.
2. It looks like a toe out problem. (I did exactly this on a 264, had to take a trip before I could get it aligned, did it by eyeball, and destroyed 2 tires in 500 miles.)
3. It also looks like you replaced a CV boot between the pictures. If you disassembled where the steering knuckle attaches to the strut, then that can also change the alignment and require a readjustment. (It depends how closely to the same spot you are able to reassemble.)
Hope this helps!
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
polskamafia mjl
Has thanked: 8 times
Been thanked: 8 times
Poland
polskamafia mjl
Post by polskamafia mjl » Tue Aug 02, 2016 7:24 pm
chrafael wrote:Abscate is right. This is classic toe out problem.
How does toe cause that kind of wear? And if that's the case what would one expect to see from out of spec camber?
Has thanked: 285 times
Been thanked: 898 times
Trinidad & Tobago
Post by abscate » Tue Aug 02, 2016 8:08 pm
Too much toe tilts the wheel under power and scrubs the inside ( toe out) or inside ( toe in).
Bad camber can also cause this but it will be on one wheel, and handling will be really fubar
Link To Volvo Glossary
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 32 times
Been thanked: 25 times
Peru
theWIFES_S70
Post by theWIFES_S70 » Tue Aug 02, 2016 9:04 pm
Thanks for the insight guys! Glad to know I didn't do anything wrong here. Will take her to get aligned and to get some new front tires and I hope not to touch her till next summer.
Oh wait, still have to repair that rear brake cable thing... :oops:
1998 Volvo S70, N/A, 5-speed, 183K
2007 Volvo S40, 2.4i, 5-speed, 97K
Trinidad & Tobago
Post by abscate » Sun Jul 01, 2018 3:29 am
Old thread alert
Torque spec is 50 Nm or 35 ft lbs per Alldata, with new hardware
I would be comfortable using old hardware this if you clean and inspect, check the diamater of the shank for wear, punch mark the nut and do the daily- weekly-monthly inspection routine...check daily for one week, then weekly for a month, then monthly for three months. At that point you can be confident the bolt is staying put.
I ran a grade 8.8 bolt on one of my ball joints this way. It had slightly excess threads so I had to make sure it cleared everything
I’ll measure my old bolt dimensions and post here. Local Volvo place would not sell me one, but you can order from LIsle and maybe FCP ?
