Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Cooling System Refresh
m96ag
Year and Model: 2000 V70XC
Re: Cooling System Refresh
Post by m96ag »
cn90 wrote:At 160K, consider radiator.
OEM vs Nissens etc., info in forum.
Radiator was replaced with a do88 all aluminum unit.
2000 V70XC 160,000mi.
Has thanked: 482 times
Been thanked: 1418 times
It comes as part of a new PCV manifold - Ill see if I can find it separate...stand by..
m96ag
Post by m96ag »
abscate wrote:It comes as part of a new PCV manifold - Ill see if I can find it separate...stand by..
I had the entire PCV replaced last week. Including the big metal pipe. Is it included in that?
Yep - life is good ...here is the diagram. If you did PCV, you replaced that last coolant hose.
Its that hose that is loose open on the diagram and connects to a banjo fitting on the rear of the engine and warms the PCV gases in the PCV system - one of the reasons our P2s don't clog as much (that and being superior people to P80s)
The banjo fitting on the left of the diagram is a vacuum fitting, the banjo on the right is a coolant fitting.
m96ag
Post by m96ag »
abscate wrote:Yep - life is good ...here is the diagram. If you did PCV, you replaced that last coolant hose.
Number 8 in the diagram was replaced. Thanks! On a side note I thought a 2000 V70 was a P80 car
Technically its a P41 car...which is (P80+P2)/2
It carries the best of both....especially the sexy Italian Throttle Body..
(I think you are technically correct, it is a P80 designation)
