Did you know? 🤔
Hood release issues with Volvo S70, V70, etc. 1998 - 2000
MrAl
Year and Model: v70, 1998
Has thanked: 0
Been thanked: 6 times
United States of America
MrAl
Re: Hood release issues with Volvo S70, V70, etc. 1998 - 2000
Post by MrAl » Mon Aug 08, 2016 11:42 pm
Hi,
Oh you mean you used something solid and not compressible? That's interesting too. I have some fender washers around already also.
1998 v70 on the road since April 2nd, 2015
MrAl
Has thanked: 0
MrAl
Post by MrAl » Mon Aug 08, 2016 11:46 pm
paredown wrote:Thanks for that--I thought I was the only one pulling the darned release twice, and having to get out of the car in between pulls to yank the hood a little.
Interesting that it worked better on the 850--probably FOMOCO cost cutting!
Hi,
Yes that was my gripe too. You would think that people that could make such good watches at one time could make a hood that opens reliably. No such luck :-)
My old 1988 Hyundai had a pretty big SPRING right at the front of the hood mounted where the plastic cowl is on the Volvo. There was no stopping that spring when the hood release was pulled because it was strong.
I also see some big bolts on either side of the hood on the car body. I wonder if something could be mounted there, like a spring, one on each side. I might look into that too.
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Been thanked: 0
98v70dad
Post by 98v70dad » Tue Aug 09, 2016 10:40 am
MrAl wrote:Hi,
The issue is that the rubber bumpers shrink over time and so does the plastic they close against. The fender washers fill the gap and you can adjust just how much you want to fill that gap by putting more than one on the stack. I chose a bolt with a flatter pan head. My repair was done about 3 years ago and is still going strong-good as day 1. Put a smaller washer on the other side so the nut doesn't pull through the plastic.
Prior to accomplishing my repair I asked a mechanic to fix the problem when I had the car in to do some much bigger jobs. He pulled the rubber bumpers down and wrapped a zip tie around each one so that it would be pushed out away from the hood. This solution puts a lot of strain on the bumper and is a crappy solution. It ticked me off when I found it because it eventually will damage the rubber bumper if left installed. However, it costs nothing and can be accomplished in 30 seconds and will get you by in a bind. That said, he charged me 20 bucks for it and earned my undying disrespect. I haven't been back since.
MrAl
Has thanked: 0
MrAl
Post by MrAl » Wed Aug 10, 2016 5:02 am
Hi,
Sad story. I dont blame you for not going back.
Also, i happen to know that tie wraps can become brittle and break over time, especially with heat cycling.
Yeah a more permanent solution would have been better.
I have to check mine next and see if i can get any of those rubber bumper things.
volare
Year and Model: 1999 V70R
Has thanked: 24 times
Been thanked: 3 times
volare
Post by volare » Wed Aug 10, 2016 11:34 am
Exactly the same issue here, '99 V70R, driver's side hood catches, gotta pull the release 2x, get out, etc etc.
Mad props to rspi as always! :mrgreen:
Jay
'99 V70R 180,500+
'06 Baja
'77 Aspen
~The Hoopty Herder~
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 11 times
sleddriver
Post by sleddriver » Thu Aug 11, 2016 2:10 pm
Nope, you're not alone. One indy's solution to my question of how to adjust the hood latches, was to pull the latch, insert a clip-board into the fender gap, then go back and pull it again. The heavy metal clip would lever the hood up enough to get ahold of it.
LOL.......
I finally dug into it one day and fixed it right. Old indy has been sniffing fuel vapors too long......
M1 10W-30 HM
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 43 times
Been thanked: 154 times
bmdubya1198
Post by bmdubya1198 » Thu Aug 25, 2016 9:43 am
rspi wrote:Hood release issues with Volvo S70, V70, etc. 1998 - 2000
That's a great idea. Wish I saved the bumpers from my old hood. Once I paint my hood, I don't want to be using my little wedge anymore, it will wear right through the paint.
2000 V70R Venetian Red/Charcoal M56 Swapped 195k
2003 S60 2.4T Silver/Black 112k
2007 XC90 V8 AWD Sport Titanium Grey/Black 166k
1991 944 Turbo Dark Green/Beige 173k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
hayesman76
Year and Model: 1998 S70, 1986 740
Has thanked: 0
Been thanked: 0
hayesman76
Post by hayesman76 » Sun Sep 04, 2016 4:20 pm
LOL That's EXACTLY what I have to do to get my 1998 S70's hood to pop the release!
j-dawg
Year and Model: 1999 V70 T5
Has thanked: 1 time
Been thanked: 19 times
j-dawg
Post by j-dawg » Mon Sep 05, 2016 9:51 am
Probably worth doing preemptively. When that hood sticks shut, it won't be a fun day.
1999 V70 T5 5-SPD | ~270k mi | burns more oil than gasoline
