IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Permatex Anaerobic sealant
Geevs
Has thanked: 0
Been thanked: 0
Geevs
Post by Geevs » Sun Sep 04, 2016 12:29 pm
HI, I'm planning to use this on my cam cover. What is the preferred method for applying - use a small foam roller or just squeeze out a bead line from the tube?
Is there any curing time?
Would appreciate any tips from those who have used this. Thanks!
beigg
Year and Model: 850 97
Has thanked: 0
Been thanked: 0
Uruguay
beigg
Re: Permatex Anaerobic sealant
Post by beigg » Sun Sep 04, 2016 4:22 pm
I foam rolled on the volvo branded goop. Did entertain using an off-brand, but time=money and I needed the turbo fridge on duty with little to no downtime.
ugh smh 850 Turbo fridge
101
Year and Model: 98 V70GLT, 98 S70T5M
Has thanked: 0
Been thanked: 0
United States of America
101
Post by 101 » Sun Sep 04, 2016 5:08 pm
The foam roller method gives you nice even coverage on the sealing surface. I wouldn't try this job any other way. Make sure you cover every little portion of the sealing surface.
There's no curing time with an anaerobic sealant ... it stays wet until the surfaces are joined together and it drys in the absence of air.
I used the Elring brand sealant from RM European and a small foam roller from Michael's craft store with excellent results. I suspect the Permatex brand sealant will be fine as well.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
rspi
Has thanked: 22 times
Been thanked: 49 times
rspi
Post by rspi » Sun Sep 04, 2016 8:06 pm
Rubber roller and Permatex every time.
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
Covert
Year and Model: 1997 850
Has thanked: 0
Been thanked: 0
Great Britain
Covert
Post by Covert » Sun Sep 04, 2016 11:06 pm
Dont put loads on though , you really dont need much at all as there are tiny oil ways in the cam cover that you really dont want to block up.
Year and Model: 850, S/V70, 06 S60R
Has thanked: 95 times
Been thanked: 282 times
Post by erikv11 » Mon Sep 05, 2016 8:29 am
Yes - applying a bead would be a getting it all wrong. Many people overdo it with the roller too: you just want a very thin layer, for example enough to make it light pink when you are using the Volvo brand (I don't know what color the Permatex is).
Nicely done:Image
vs. too much: Image
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
gone: '96 NA 850 210k, '98 NA V70 182k
Has thanked: 7 times
Been thanked: 25 times
Post by MadeInJapan » Mon Sep 05, 2016 9:01 am
I used the Permatex too...it is pink like the pictures when applied correctly with a foam roller.
Covert
Has thanked: 0
Been thanked: 0
Great Britain
Covert
Post by Covert » Mon Sep 05, 2016 9:32 am
As above a very light layer , its got 40 bolts holding the thing down so its not going to move much !
alschnertz
Year and Model: 1995 854T
Has thanked: 1 time
Been thanked: 9 times
alschnertz
Post by alschnertz » Mon Sep 05, 2016 9:56 am
I squeezed out a bead (no roller) and have not found any ill effects. I did not GLOP it on and used a very small diameter bead.
It's been over a year and all seems well.
I used the Permatex Anerobic.
'84 Prelude
'06 MPV
'13 Ford Focus SE
Geevs
Has thanked: 0
Been thanked: 0
Geevs
Post by Geevs » Mon Sep 05, 2016 10:21 am
Many thanks to everyone for their feedback - much appreciated!
