IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Intercooler - repair or replace?
Has thanked: 14 times
Been thanked: 230 times
Canada
Post by scot850 » Tue Oct 04, 2016 1:50 pm
My never ending PITA 2000 R has added to it's never ending broken parts. Removed the broken radiator today to replace it, only to fing that the Volvo OE radiator has a weird small outward (4-5mm wide by 3mm outward) standoff that has rubbed a nice little hole in the center of the intercooler. Why it is there who know, but not fitting another OE radiator, so the question is, can these be successfully repaired? The hole is maybe 1-2mm diameter max, otherwise the intercooler is in excellent condition. My car has a tune and boosts to around 18psi, so any thoughts if I take it to a radiator shop for repair is it something that can be done, or am I better off just biting the bullet and replacing?
Thanks,
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 580 times
Been thanked: 226 times
United States of America
matthew1
Re: Intercooler - repair or replace?
Post by matthew1 » Tue Oct 04, 2016 2:11 pm
Neil, sorry to hear.
It won't hold probably... but if you don't mind (and are quick with) getting the radiator/intercooler on/off, might as well try. See my blown Volvo 850 intercooler saga. I ended up replacing with a used OEM intercooler.
The hole must be small enough to be inconsequential to boost pressure, otherwise you'd have felt a noticeable drop in boost and power.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Year and Model: Many Volvos
Has thanked: 4 times
Been thanked: 53 times
Post by Ozark Lee » Tue Oct 04, 2016 4:52 pm
I repaired the bottom of an intercooler where it smacked a parking block with some fiberglass and epoxy. It wasn't pretty but it worked. A rub through the actual heat exchanger part likely isn't repairable but I suppose you could take it to a radiator shop to get an opinion.
Canada
Post by scot850 » Tue Oct 04, 2016 6:03 pm
Thanks guys for the input. I've attached pictures below:
Intercooler with small dark patch at middle bottom
Picture above is of whole of rear of intercooler facing the radiator front. Dark patch at center lowest point is where hole is.
Hole at bottom of intercooler
Here you can see the hole rubbed through by the radiator standoff.
Radiator rub partner
The radiator picture is too large to up-load, but this is the standoff or rub point that caused the hole.
I have spoken to a supplier of high quality OE Volvo parts that will supply a guaranteed and tested part for about $300 + shipping (CDN)
Dealer has offered a new one for about $530 CDN which is a good price relative to on-line US suppliers but without any shipping costs.
Typically no turbo V/C/S70's in PnP just now and with snow in the forecast!
Radiator repair specialist says can't repair it, but suggested a specialist aluminum repair company. They say it may not be repairable, but to bring it in tomorrow and they will assess. They have a welder who specialises on small repairs. If he says no then it is not fixable.
The used part supplier suggested filling the hole with a small aluminum self tapping screw covered in JB weld.
I guess we will find out tomorrow!
2006 XC70
beigg
Year and Model: 850 97
Has thanked: 0
Been thanked: 0
Uruguay
beigg
Post by beigg » Tue Oct 04, 2016 6:11 pm
might be able to pop a rivet gooped in jb weld in the hole, until funds permit a replacement...
ugh smh 850 Turbo fridge
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 335 times
Been thanked: 1035 times
Trinidad & Tobago
Post by abscate » Tue Oct 04, 2016 6:13 pm
A nice goober of JB weld will fix that nicely, Neil
Eschew the replacement for the wonders of epoxy
Even if it leaks a little, it won't hurt performance - remember there is a blow hole at the bottom for moisture.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 44 times
Been thanked: 158 times
bmdubya1198
Post by bmdubya1198 » Tue Oct 04, 2016 6:35 pm
No reason you can't use JB weld as a temporary fix. Check on CL locally for people parting out turbo Volvos and get a used intercooler from them. Also check on eBay... there are usually wreckers who will have them listed. I had to rely on that for parts for my 300zx, they never show up in Pull-A-Parts.
abscate wrote: Even if it leaks a little, it won't hurt performance - remember there is a blow hole at the bottom for moisture.
I forgot about that... that would explain the oil residue on the bottom of my intercooler...
2000 V70R Venetian Red/Charcoal M56 Swapped 197k
2003 S60 2.4T Silver/Black 113k
2007 XC90 V8 AWD Sport Titanium Grey/Black 171k
1991 944 Turbo Dark Green/Beige 174k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Year and Model: 850, S/V70, 06 S60R
Has thanked: 101 times
Been thanked: 295 times
Post by erikv11 » Tue Oct 04, 2016 7:18 pm
abscise wrote: ... Even if it leaks a little, it won't hurt performance - remember there is a blow hole at the bottom for moisture.
This ^^
EDIT: LOL some kind of spell check hit your username?
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
gone: '96 NA 850 210k, '98 NA V70 182k
Canada
Post by scot850 » Tue Oct 04, 2016 7:40 pm
Thanks guys. Have looked locally and on ebay for intercoolers (used) but none currently available. These later ETM motors are a pain due to the proximity of the radiator to the turbo intake pipe at the ETM. So removing this again in not something I really want to do in the near or any future! LOL. With my daughter's car to buff/polish and clean for sale, 3 sets of winter rims to fit and summers to clean, I have enough work for a while, so don't need any others, especially as having adjusted the hood release and tested it multiple time, went to open the hood for the repair and again back to the refusal to release on the LHS again without downward pressure. Like I said this car is pushing me ever closer to getting rid of it as I am just plain fed up spending more time fixing than driving it!
I'll see what tomorrow brings in terms of the welding route. If that pans out then I have to make a decision on new/used/or attempt a repair of some form. Fair point on the drain hole, totally forgot about that also. For all the area involved could even glue a small plate over the hole and then put a rubber patch to act as a pressure point on the edge of the radiator frame to hold it in place.
Thanks again one and all!
2006 XC70
matthew1
Site Admin
matthew1
Post by matthew1 » Tue Oct 04, 2016 8:39 pm
That hole is tiny. And it's in the metal. I think it's repairable. Now that I've seen it (good photos), scratch my original pessimism, I'm with the rest of the guys.
Also -> Amazon link
