Did you know? 🤔
850 slowly lost rpms-will start- can rev- but idles and dies
Turbolena
Year and Model: 850 Turbo Wagon 1994
Has thanked: 0
Been thanked: 0
Switzerland
Turbolena
Post by Turbolena » Thu Nov 03, 2016 8:03 am
Hello,
I could use a hand figuring this out . The car had been running great, smooth driving, smooth shifting, and a nice purr on idle.
I have a 1994 850 turbo wagon. Wife was driving it last night and the car slowly lost rpms until stalled out. It did restart a couple of times but in a very rough idle it then lost rpms and killed each time. We had it towed to a mechanics lot, but I went out last night to retrieve the codes listed below is what I found. Also, at that point I started it up, it turned over no problem and I was able to rev the engine and it did sort of stay engaged, but was pretty rough and then if I let off the gas rpms dropped and it died, with traction control light and some other dashboard stuff blinking . In the recent past it has seemed like the PNP swtich was going bad, as I a few times I would need to move the shifter to get the car to start , but that hasn't happened in months.
Here are the codes. The front knock sensor and the preheat codes have been there for a couple of years, even after I replaced both O2 sensors. Could the knock sensor finally have faulted...I don't remember the rear knock sensor showing up before.
A1 - 1-1-3, 1-1-4,
A2- 5-2-1, 1-4-3, 4-3-3, 2-1-2, 3-2-5
A7 - 1-1-1
and then I swear I was in the right port for A3 - but got codes that don't seem to be on the list
2-1-3,2-1-4,1-4-1,4-4-3,1-4-2,1-4-4
Any help would be appreciated!
misha
Has thanked: 39 times
Been thanked: 102 times
Serbia
misha
Re: 850 slowly lost rpms-will start- can rev- but idles and dies
Post by misha » Thu Nov 03, 2016 10:55 am
Clear those codes and see which ones comes back.
Here is the list of the codes:
http://volvospeed.com/volvo_repairs_how ... es_a2.html
"A2" Codes are pointing to both knock sensors,O2 sensor and memory fault which could point to bad ecu(which is unlikely).
The things which manage them are ecu and relays.Check MAIN fuel injection relay on fan shroud (grey one)under the hood and fuel pump relay.ALSO check for blown fuses in fuse box.ECU & TCU fuse should be #1,but check fuse list to be sure.
"A1" codes are transmission codes which are pointing out bad TCU(which is HIGHLY unlikely for both ecus to go bad)& p'n'p switch.
http://volvospeed.com/volvo_repairs_how ... codes.html
Bad voltage supply or bad ground could be the culprit at this stage.Does the alternator works properly and what condition is the battery and battery cables?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kahl
Year and Model: 2000V70XC
Has thanked: 0
Been thanked: 7 times
United States of America
kahl
Post by kahl » Thu Nov 03, 2016 3:01 pm
Unplug the MAF sensor and see if it runs. Codes can cascade when this sensor goes bad.
Has thanked: 0
Been thanked: 121 times
Post by cn90 » Thu Nov 03, 2016 5:21 pm
1+,
I have the same experience (random stalling), turned out it was MAF.
New Bosch MAF solved the stalling.
But you need to check the usual stuff...air filter, fuel filter, plugs, cap, rotor etc.
