IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
What did you do to your Volvo today?
Year and Model: 2001 V70
Has thanked: 58 times
Been thanked: 127 times
Post by volvolugnut »
So, you have fuel, spark, and compression (assumed on all cylinders), but do they occur at the proper time in the crank cycle? Has this car ever ran for you?
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 376 times
Been thanked: 1176 times
:D
It has never run for me, no.
:D
Compression, timing, shark all good
Time to turn to fuel delivery ...what parts to throw at it? :roll:
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
ZionXIX
Has thanked: 9 times
Been thanked: 46 times
Post by ZionXIX »
Fuel pressure? Injectors? Fuel pump, pressure regulator, fuel filter
Fuel pressure at rail first, then injector volume/pattern
FLXC90
Year and Model: 98 V70 T5
Has thanked: 7 times
Been thanked: 33 times
Post by FLXC90 »
Didn't your mother teach you not to throw parts (or your shop teacher!)
Current Volvos:
On the edge of starting a thread for this crank, no-start.
!998 V70 NA
New reworked cylinder head - planing, valve lapping, valve guide seals
Compression test ok cold, wet at 150-180 psi
Have good spark at Number one plug
New cap and rotor
Supply voltage at fuel injectors in 12.4V with battery at 12.5V
Fuel pressure 38 psi at key on, 42 psi during cranking
Fuel pressure holds for 30 minutes
Engine timing confirmed correct, non VVT engine of course.
Cookeh
Year and Model: 1995 Volvo 850 T5
Has thanked: 54 times
Been thanked: 29 times
Post by Cookeh »
CPS?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 37 times
Been thanked: 36 times
Post by Sveedy »
Did the PCV upgrade and it helped with the pressure.
I used ZionXlX's internal spring idea, but incorporated a EMT sweep for the 90*
3ft of the oil resistant 5/8" hose ( from a heavy equipment parts store )
4ft of the same in 1/4"
A relatively light compression spring
1/2" EMT sweep
$ 20 and change.
Don’t forget to remove the bracket from that starter in the right side
Volvo discontinued that and no longer replaces it
The two m10s and the pins hold the starter in fine.
abscate wrote: Mon Aug 10, 2020 10:04 am On the edge of starting a thread for this crank, no-start.
!998 V70 NA
New cap and rotor
Spark plugs new
Today’s chapter. Noticed engine relay was not pulling in. Swapped with air pump them spare.
Relay now pulls in
Still no start.
