Did you know? 🤔
Compare the wagons! P2 vs. P80
beigg
Year and Model: 850 97
Has thanked: 0
Been thanked: 0
Uruguay
beigg
Re: compare the wagons!
Post by beigg » Sat Nov 26, 2016 11:16 am
Catch can and hose end caps. Probably be same or less cost in parts.
ugh smh 850 Turbo fridge
jimmy57
Has thanked: 4 times
Been thanked: 237 times
jimmy57
Post by jimmy57 » Sat Nov 26, 2016 12:13 pm
05 V70 8
96 855 2
2005 will not need: an evaporator, a whole lot of broken dash stuff repaired, RH airbag cover warpage repair, a new battery every 4 years.
Both will need spring seats and some front end bushings.
2005 is a better ride, quieter, colder a/c, better sound system and several other things improved or more modern.
2005 has less module failures (CEM in particular) comparted to 99-2004 P2 models.
misha
Has thanked: 56 times
Been thanked: 130 times
Serbia
misha
Post by misha » Sat Nov 26, 2016 2:13 pm
beigg wrote:Catch can and hose end caps. Probably be same or less cost in parts.
Catch can will not be helpful if oil ports are blocked.It can only help with blue smoke from exhaust.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
beigg
Has thanked: 0
Been thanked: 0
Uruguay
beigg
Post by beigg » Sat Nov 26, 2016 5:16 pm
jimmy57 wrote:05 V70
This!
Ac suspension and interior noise im not concerned with.
I do like a firm reassuring suspension and very good heat.
What breaks apart 99-04 to 05+ ?
jimmy57
jimmy57
Re: Compare the wagons! P2 vs. P80
Post by jimmy57 » Sat Nov 26, 2016 6:15 pm
The P2 models had a major electrical change for 2005. Most relays dumped in favor of transistor power control, this allowed limiting bulbs to 13V for longer life. CEM and REM had complete renovations. Steering wheel module was revised. High speed CAN network (ABS, ECM, TCM [auto trans], DEM, and CEM) had comm speed increased to 500kbps from 250 kbps.
beigg
Has thanked: 0
Been thanked: 0
Uruguay
beigg
Post by beigg » Sat Nov 26, 2016 6:56 pm
Good explanation. Im not sure if I'd like the 05 steering system.
Obd2 speed has been an aggravation with p80's.
