IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
93 850 consensus on spark plugs?
JimBee
Has thanked: 13 times
Been thanked: 28 times
Post by JimBee »
I think it's time. Bosch coppers? Others?
rspi
Has thanked: 22 times
Been thanked: 50 times
Re: 93 850 consensus on spark plugs?
Post by rspi »
Volvo OEM.
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
misha
Has thanked: 59 times
Been thanked: 164 times
Post by misha »
Volvo oem or equivalent:
-NGK BKR6ETUC
-EYQUEM RFC 52 LS3
...the ones which are inside of Volvo oem spark plug package. ;)
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
Bosch, NGK coppers work fine and are inexpensive. Denso is another option. No on Bosch platinum. Yes on NGK platinum. What does your manual say?
M1 10W-30 HM
JimBee
Post by JimBee »
I got the NGK coppers, will install them tomorrow.
Ignition is working. I used the inline tester and a ground wire on the plugs to test each one; they all spark, a couple brighter than the others. And they smell of gasoline so I guess some fuel is spritzing into the cylinders—and there's plenty of pressure at the fuel rail / schrader valve.
Strange that in June it started instantly after sitting since February, which is how it has always started in the 8 years I've owned it, even after sitting for long periods. But now not even a pop, no hint of life!
Maybe the plugs will make a difference. Seems like a long shot.
sleddriver
Be sure to properly gap.
I myself would never let any car sit that long without starting it.
M1 10W-30 HM
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I have good luck with Bosch copper. They won't last as long as O/E though.
Good luck.
Has thanked: 117 times
Been thanked: 337 times
:lol: a no-start problem sneakily disguised as a plug question!
My first thought is lawn mower syndrome, definitely give the oil-in-each-cylinder routine a try.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
