Did you know? 🤔
1993 850 Coolant Recovery Tank Interchange?
slantvaliant
Year and Model: 1993 850
Has thanked: 0
Been thanked: 0
United States of America
slantvaliant
Post by slantvaliant » Sun Dec 04, 2016 6:45 pm
What is the interchange on 1993 850 coolant recovery tanks?
I found the part number 9141106, listed for '93s, and 9141095, which at least one vendor says will fit but is listed for '94-up applications.
rspi
Has thanked: 22 times
Been thanked: 50 times
rspi
Re: 1993 850 Coolant Recovery Tank Interchange?
Post by rspi » Sun Dec 04, 2016 7:27 pm
Should fit. I seen no difference in the '93 850's that I've seen.
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
Has thanked: 18 times
Been thanked: 250 times
Canada
Post by scot850 » Sun Dec 04, 2016 10:57 pm
Vida shows 2 different tanks, one for -93 and another for 94-98. Don't know what the difference is as the pictures for both parts on Vida look identical with one larger pipe running to the back of the engine and another pipe to a connection on the thermostat housing. Maybe the method of the part mounting is different?
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Spain
shaker_chi
Post by shaker_chi » Tue Dec 06, 2016 3:12 pm
Whatever you do, do NOT buy an aftermarket tank. They last about 6 months and will split and crack right on the seam. Better off getting a used O/E at a pick and pull if you are tight on cash.
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Been thanked: 0
98v70dad
Post by 98v70dad » Tue Dec 06, 2016 4:20 pm
If anything about a part changes most companies will change the part number or dash number. If the part number is for an assembly and any part in the assembly has been changed the assembly part number will be changed. So say volvo or its supplier hypothetically decides to change the type of plastic in the tank. You wouldn't necessarily be able to tell a new tank from the old one because they would be identical as far as you could tell by looking at them. If parts change and new part numbers aren't assigned companies can get faced with combined stock and not being able to tell one part from another if they are very similiar.
misha
Has thanked: 59 times
Been thanked: 153 times
Serbia
misha
Post by misha » Tue Dec 06, 2016 6:42 pm
They all look the same to me.
Maybe the ones up to '94 doesn't have a low coolant sensor in it....just a guess.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 103 times
Been thanked: 312 times
Post by erikv11 » Tue Dec 06, 2016 7:03 pm
shaker_chi wrote:Whatever you do, do NOT buy an aftermarket tank. They last about 6 months and will split and crack right on the seam. Better off getting a used O/E at a pick and pull if you are tight on cash.
I totally agree.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
shaker_chi
Spain
shaker_chi
Post by shaker_chi » Wed Dec 07, 2016 9:43 am
I have an early base 94 with the 1993 taillights, aluminum control arms, etc. and my tank has a low level sensor on it.
