Amazon Black Friday deals
V70 GLT losing coolant - into transmission?
macs70GLT
Year and Model: S70 GLT 1998
Post by macs70GLT »
Quick history on the car, my son bought this 98' V70 GLT last summer on my recommendation. We intended for him to drive it from WA state to NM where he goes to college. PO had told us he did the head gasket due to overheat when his wife was driving it. We bought the car without a good thorough check - just a drive & my looking it over (doh!!!)
I have done various things over the summer including swap out of oil cooler lines (my least favorite job on these), ABS module, changed all coolant hoses etc.
Over the last month it has been losing/using coolant. I did identify a small leak at turbo return rubber hose so tightened that clamp. Last night I ran the UV die through the system & found no evidence of leaks.
However - it was leaking transmission fluid a couple months ago (appeared to be coming out at the axle). I'm now wondering if there is a leak inside the radiator, enough to raise the level of tranny fluid.
1. wouldn't I see signs of transmission fluid in the expansion tank?
2. wouldn't a damaged head gasket (burning coolant during combustion) also show signs of oil in expansion tank?
3. what else can I do to check for coolant leaks?
I have not yet pulled spark plugs to check those for signs of coolant.
Thanks guys!
Mike
Lars: 1988 245, 250K mi retired
Son of Lars: 1998 S70 GLT, 225K mi retired
Beast Mode: 1995 940T, 213K mi
Son's car: 1998 V70 GLT, 182K mi
Hans: 2002 Audi A4 QMT, 142K mi
misha
Has thanked: 63 times
Been thanked: 166 times
Re: V70 GLT losing coolant - into transmission??
Post by misha »
Does the car have automatic transmission?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
macs70GLT
Post by macs70GLT »
Hi Misha
Yes it's the automatic. I'm planning to drain & fill the transmission with Mobil 1 Synthetic ATF, probably will do it twice in next couple weeks. Then I'm driving it from WA state down to New Mexico.
I should also point out I have not driven the car much, it has been parked. Coolant level has dropped about half volume of expansion tank 2 or 3 times since I replaced all the hoses.
Thanks
Mike
misha
Post by misha »
Ok....next step would be to check transmission oil level on transmission dipstick.If oil isn't contaminated with coolant and if it is at proper level....than it's ok.
However....if radiator chamber for transmission oil is ruptured it would also contaminate coolant.
Check driver's side footwell carpet for coolant traces....could be that heater matrix is leaking....or could be a headgasket.Maybe the seller didn't replace it like he said before he sold the car.
If transmission oil is ok,coolant ok,heater matrix also ok,no other visible signs of coolant leaks at hoses...than the engine is burning coolant because of blown headgasket.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rspi
Has thanked: 22 times
Been thanked: 50 times
Post by rspi »
The bad thing about coolant leaks is that when hot, the coolant evaporates real fast. May never leak to the ground.
#1 check heater core. If it has not been replaced recently, it may be a time bomb.
#2 Check water pump. If it is more than 10 years old or is an after market pump, it may be seeping. Mine leaked for about 18 months before it failed.
#3 Radiator. If it's seeping into the transmission, the transmission fluid will look like coffee with cream or chocolate milk. I have head of the rad leaking into the trans and not flowing the other way. I'm actually planning to bypass my rad with an external transmission cooler.
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
macs70GLT
Post by macs70GLT »
Thanks Misha & Robert
The heater core shows no signs of leaking directly underneath, and since I ran the UV die through the system there should have been traces of the coolant/die mix remaining - so I'm considering that good.
If the pump is seeping I wouldn't see it, so that may still be a culprit. I need to change out that motor mount anyway so that will give me a good closeup look of the area.
Regarding the trans fluid, I'll check that again. I've never been confident in reading the level accurately since it varies so much with temperature - planning to drain some & replace with Mobil 1 synthetic in the next few days.
One question - is it possible the system just had enough air after changing radiator hoses that it needed to be topped up 2 or 3 times?? My Audi A4 is difficult to fill, have to elevate the expansion tank to get it done properly.
Robert I'll check out your videos tonight, thanks for creating those! A great resource for the shadetree mechanics ...
Mike
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 10 times
Post by jblackburn »
Re-filling ~2 times seems about right from what I recall.
Check with trans fluid warmed up, car idling in park, trans stick level side pointed at the sky.
'98 S70 T5
2016 Chevy Cruze Premier
Been thanked: 282 times
Agreed with the several tops up required. I reckon my last radiator took 4-5 fills to settle it, but most have been 1-2 to purge the air.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
misha
Post by misha »
macs70GLT wrote:...If the pump is seeping I wouldn't see it...
Yes you would.Just by the crankshaft where right lower engine mount is.If water pump is leaking from a weep hole,coolant would drip under the car and you would see that.
You can also remove timing belt cover and check the area that way.You would have a better view and you would see everything.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
KurtL
Year and Model: V70 2001
Post by KurtL »
I have experienced slight coolant leaks from both expansion tanks on my 01 V70 and 08 C30. I have had leaks from the the radiator, heater core and heater core O rings that were all almost impossible to detect.
The tank is an easy do it yourself fix that is easy to replace and rule out.
