IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
98 V70 brake front and rear brake calipers
98v70dad
Year and Model: 98 V70
Has thanked: 1 time
Post by 98v70dad »
Is there any rebuilt caliper brand that is the best value? I know that the cheapest (and probably the best) way to handle "fixing up" old calipers is to replace the seals, etc. but I'm looking for the quick solution since I cant have the car out of service for very long.... off with the old and on with the new in an afternoon .... Rebuild calipers is what I would like to do unless it will cost a fortune or I would end up junky parts.
Any comments offered would be helpful. Thanks
Has thanked: 22 times
Been thanked: 273 times
Re: 98 V70 brake front and rear brake calipers
I have used Cardone several times on my Volvos and only had one problem one that was replaced under warranty. Most that I have had have Volvo cores. I had another brand also but can't remember the name. I used them as they were the only ones with calipers for the rear of my 2000 V70R (one year vented rear rotors only on 'R' models).
I am about to replace the rears on my 2000 V70 base and they will most likely be Cardone. My reason for this is that as you have to pay a core charge, it is cheaper for me to buy locally so I can return the cores without a crap load of shipping costs. Also issues are easier to deal with.
The only concession I make is fitting Volvo bleed screws as the replacements are usually of a poor quality.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
my last cardone ones had some sort of clear coat on the pistons that peeled off- after that I just rebuilt ones I had
The reason I have not re-built my calipers in the past is they are usually so rusty it is not worth it. If you can re-build them and can find goon new pistons and seals then go for it.
2006 XC70
Clemens
Has thanked: 98 times
Been thanked: 57 times
Post by Clemens »
Before you start the job be sure to have a really good 11mm flare nut wrench on hand (ask me how i know it is important).
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 387 times
Been thanked: 1219 times
Abscate few pearls of wisdom. Crack the bleeders and the hose flare nut while the calipers are still attached, not after removal.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
oragex
Year and Model: S60 2003
Has thanked: 100 times
Been thanked: 299 times
Post by oragex »
Not sure about rebuilds.. but used OEM ones that don't look too rusty from a scrap yard it's a smart move. Even Ebay should be affordable. There are plenty of owners who had parts replaced by the main dealer before their car went to scrap. I just pulled two new OEM end links :)
Plus as above, the flexibles are to be undone with the caliper on the car 8)
98v70dad
Has thanked: 1 time
Post by 98v70dad »
oragex wrote:Not sure about rebuilds.. but used OEM ones that don't look too rusty from a scrap yard it's a smart move. Even Ebay should be affordable. There are plenty of owners who had parts replaced by the main dealer before their car went to scrap. I just pulled two new OEM end links :)
The junkyard something I hadn't thought about. Good idea, although I'd rather take the old ones off and put the new serviceable part on without spending a half day picking through the junkyard and another half day or more rebuilding what I find. I spend way too much time on this car and I don't have a lot of free time.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
abscate wrote:Abscate few pearls of wisdom. Crack the bleeders and the hose flare nut while the calipers are still attached, not after removal.
You, sir, are very wise. I replaced the front hoses a few years ago and they didn't come off easy.
98v70dad
Has thanked: 1 time
Post by 98v70dad »
Clemens wrote:Before you start the job be sure to have a really good 11mm flare nut wrench on hand (ask me how i know it is important).
I bought a set of Craftsman flare nut wrenches a few years ago. They are NICE. Here's why I bought them. I tried to remove the front hoses with a much cheaper tool that I bought at an auto parts store years before and I half rounded off the nut on both sides, so I took a break, bought the better wrenches (expensive as I recall) and I was back in business. For some reason I still have the crummy wrenches. They need to be tossed because they are worthless except for scrap value, maybe.
