We're back... on a new server. You can post normally. I'll be working on bugs this evening, so you may encounter abnormal forum behavior. Apologies for the inconvenience!
MVS-Amazon link helps MVS!
Uneven tire wear after new tires with alignment
shiloh51933
Has thanked: 11 times
Been thanked: 10 times
Post by shiloh51933 »
So my front tires wearing on outer shoulders with alightment, both hub bearings replaced with premium hubs and everything else seems solid. More worrisome is inner rear shoulder wear that is literally almost on inner side wall. Now my rear nivomats sometime sit low or sit high half the time.
The fronts might be do to 100 miles a day of making local deliveries with her.
2000 V70XCSE.
If U Wanna Play U Gotta Pay!!
sleddriver
Year and Model: 1998 V70 T5
Been thanked: 12 times
Re: Uneven tire wear after new tires with alignment
Post by sleddriver »
No XC AWD experience here, however I too experienced severe inner tire wear on the rear pass. side. Much worse than I ever thought. When I went for a 4 wheel alignment last year, the rear end was significantly out. So much that you can now clearly see the new shiny steel previously covered by the bolts.
You may want to have your alignment verified. Be sure they start with the rear FIRST.
Given your daily mileage, location and driving deliveries, consider cross-rotating your tires at least every 5000 miles.
M1 10W-30 HM
shiloh51933
sleddriver wrote:No XC AWD experience here, however I too experienced severe inner tire wear on the rear pass. side. Much worse than I ever thought. When I went for a 4 wheel alignment last year, the rear end was significantly out. So much that you can now clearly see the new shiny steel previously covered by the bolts.
I appreciate reply, yeah I drive quite bit so that explains front outer shoulders but what's up with rear inner shoulders. It's not running up against anything.
Has thanked: 22 times
Been thanked: 301 times
Definitely have the rear tracking checked. There are many opportunities for wear in the rear AWD suspension. Check all the bushes for wear, especially the bushes in the trailing arms (both ends).
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
shiloh51933
scot850 wrote:Definitely have the rear tracking checked. There are many opportunities for wear in the rear AWD suspension. Check all the bushes for wear, especially the bushes in the trailing arms (both ends).
Since I left the Lexus dealership I have no access to an alignment machine, so I ponied the dough and went to the Firestone that I get tires from to get the wheel alignment. They did the wheel alignment, printed up before/after results as requested and everything looked good. When I was underneath her I couldn't find anything wrong but it's hard to tell with the rear bushings sometimes with trailing arms. Wouldn't the tires wear unevenly if the shocks/Nivomats were riding majorly low in the back?
brick_and_motor
Year and Model: 1998 V70 GLT;
Post by brick_and_motor »
Definitely check the bushings. If you routinely carry a load in the car, might not be a bad idea to have them recheck the alignment with weights in the back to simulate routine driving conditions.
1998 V70 GLT
1998 S70 NA
1988 Chevrolet C1500
