Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
MVS-Amazon link helps MVS!
Intake Manifold, which bolt goes where? Topic is solved
Has thanked: 443 times
Been thanked: 1339 times
Re: Intake Manifold, which bolt goes where?
Clamp,with the rubber bushing holds the thick brake booster vacuum hose
Link To Volvo Glossary
Cook.p.michael
Year and Model: 1996 850 turbo 2.3
Post by Cook.p.michael »
bump
Has thanked: 129 times
Been thanked: 364 times
Re: Intake Manifold, which bolt goes where?  Topic is solved
first pic: clamps onto the drivers side of the head, holds the vacuum tubing.
second pic: lower drivers side intake manifold bolt, holds the PCV pipe
third pic: the thinnest ones look like MAF screws, the pointy ones look like cowl screws, the blunt ones look like cam cover screws.
fourth pic: this bracket houses the connectors for the cam sensor and crank sensor, also goes on the end of the head like pic 1.
fifth pic: heat shield, over exhaust, firewall side of head
sixth pic: heat shield screws
seventh pic: I see a thermostat housing gasket (two rectangles), then turbo return gasket and/or SAS pipe gasket, some AC o-rings
eighth pic: Fuel line bracket (the smaller one) and I've seen the other piece but drawing a blank.
ninth pic: I think it goes down on the transmission, for the bundle of wires to the PNP, would have to look.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6 :shock: 130k
Cook.p.michael
Thank you much, i know foreign cars are meant to have extra parts but this is too many :D
