I did new pads on rears on the 1999 last year , or two?
Stopping power is great but the squeal like " Deliverance" even with new rotors
This is great for two reasons
Pedestrians hear you coming
If you practice a bit, you can play " Dixie" coming to a stop, which amuses me
p80 rear brake pad review. Pagid brand
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 456 times
- Been thanked: 1359 times
Link To Volvo Glossary
- Year and Model: 96' 850
- Has thanked: 66 times
- Been thanked: 45 times
I have had great success eliminating the noise by installing the "anti squeal shims" from Volvo and using a liberal amount of Permatex brake paste on the back of the pads:abscate wrote:I did new pads on rears on the 1999 last year , or two?
https://www.amazon.com/gp/product/B0018 ... UTF8&psc=1
96' 850 sedan, base, auto, pewter/charcoal, 118k miles
99' S70, base, 5-speed manual, nautic blue/ tan, 218k miles
05' V70, 5-speed manual, loaded, mistral green/ tan, 151k miles
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 22 times
- Been thanked: 309 times
Many years ago, in Europe, we used to have bumper stickers that read, IF IT SQUEELS, IT'S A VOLVO! This issue comes up many times and the solution is to fit the shims, or learn to amuse yourself with them as you do!
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
2006 XC70
- wizechatmgr
- Has thanked: 27 times
- Been thanked: 72 times
I've always had copper spray that I'd hit the backs with and then lube the heck out of the slider pins. Not sure if this is any different with a Volvo but it works fine on the MC and previously on the Dodge, VW and Ford.
1999 V70 XC AWD 2.4 T -- ~193k miles
1998 V70 2.4 NA -- ~180k miles
- Has thanked: 54 times
- Been thanked: 206 times
I think I should have gone heavier with the brake lube. I have Centric brakes from the wonderful (not) Rockauto. "C-tek" rotors and ceramic pads. They don't stop that great and they make a whirring/squealing noise while I drive, but it's intermittent. They're much better than my old original 174k-mile rotors, but they aren't as good as I would like. At least they stop quietly. It could be that I somehow bled the brakes wrong, but I highly doubt that. I got all the air and a lot of nasty old fluid out of there, the master cylinder looks very clean now.
Oh well, I'll live with these until I upgrade to 302s with some Akebonos.
00 V70R Venetian Red/Charcoal M56 Swapped 202k
03 S60 2.4T Silver/Black 122k
07 XC90 V8 AWD Sport Titanium Grey/Black 180k
98 V70 GLT Black/Beige 205k
00 S70 GLT Mystic Silver/Taupe 254k
99 BMW 528i
84 BMW 318i
04 Saab 9-5 Aero
01 Mountaineer 5.0- to tow all these cars
91 944 Turbo
99 BMW 528i
84 BMW 318i
04 Saab 9-5 Aero
91 944 Turbo
- wizechatmgr
Unknown to most but cars that have ABS can get air stuck in the ABS control module/manifold occasionally and it isn't fun to get out. Usually you require a dealer level scan tool to open up all of the valves to bleed it correctly using a vacuum bleeder. Whatever you do -- don't let the reservoir run dry.
Oh great... that sounds like loads of fun. Yeah, I never let it run dry. That's just a way to introduce more air into the system... rather counterproductive method of bleeding your brakes.wizechatmgr wrote:Unknown to most but cars that have ABS can get air stuck in the ABS control module/manifold occasionally and it isn't fun to get out. Usually you require a dealer level scan tool to open up all of the valves to bleed it correctly using a vacuum bleeder. Whatever you do -- don't let the reservoir run dry.
99 BMW 528i
84 BMW 318i
04 Saab 9-5 Aero
91 944 Turbo
99 BMW 528i
84 BMW 318i
04 Saab 9-5 Aero
91 944 Turbo
