Check engine light with no code
Golden86
Year and Model: 1996
Post by Golden86 »
96 Volvo 850 Turbo automatic motronic 4.3
I have had a persistent check engine light with no codes that I can pull with an OBDII reader. I clear it and it comes back after a few miles of driving. I was able to make a a led/switch to read the flash codes off my ecu, and they show 1-1-1. The only code I'm getting is from the vol-fcr and reading the cluster codes. It is showing code C1-221 (vehicle speed signal missing). Can the cluster throw a check engine light for this code? If so, how can I test it?
Any help would be greatly appreciated.
Thanks
MadeInJapan
Has thanked: 7 times
Been thanked: 27 times
Post by MadeInJapan »
Speed missing is when you haven't driven 35mph yet- it comes up on all cars. You sure this isn't the service light and that just needs resetting (of course after you change your oil).
Golden86
Post by Golden86 »
not service light, definitely the check engine light
Sommerfeldt
Year and Model: 1996 850 T5
Has thanked: 55 times
Been thanked: 38 times
Post by Sommerfeldt »
Did you read the codes from the transmission? The tranny can call the ECU to light up your christmas tree if it wants to. The codes can be hard to read on M4.3, and even harder to reset sometimes, but if the ECU doesn't give you a code, the transmission is probably the next stop I'd make.
- S
'96 855 T5, R bumper and spoiler, Koni Yellows & blue H&R springs all 'round.
Golden86
Post by Golden86 »
No codes from the trans via vol-fcr.
Golden86
Post by Golden86 »
Quick update for anybody who may have the same issue. I wanted to make sure the ecm is throwing actual codes, so I pulled the MAF sensor and tried reading the codes again. This time the MAF error came up on my OBD2 reader, so I know that works. I also read the codes through the flash tool, the MAF code popped up, and one more code, Rear O2 low voltage.
Replaced rear O2 and the code never came back. This just shows how finicky the volvo can be, make sure to check all your avenues.
