Did you know? 🤔
Oil cooler lines leak 98 volvo v70xc Topic is solved
Has thanked: 17 times
Been thanked: 232 times
Canada
Re: Oil cooler lines leak 98 Volvo v70xc
Post by scot850 » Fri Apr 14, 2017 2:31 pm
Forgot to add, used Blue devil for a suspected rear main leak when running an 850 to California. Car had been sitting, but started leaking somewhere in Nevada after a hard drive. Filled with Blue Devil and by the time we got to California all was good and has not leaked again since. I look at the hope they help 'condition' an old seal, but don't really look on them to fix a pipe leak or 'O' ring type leak.
Also, do not break the oil cooler thermostat as they are now an obsolete part and only available used.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Switchemlee
Year and Model: 1998 v70 xc awd
Has thanked: 0
Been thanked: 0
United States of America
Switchemlee
Post by Switchemlee » Sat Apr 15, 2017 4:17 pm
Thanks for all the tips i found my lines were leaking at the crimped part of the hoses on the bottom crimpings. Not sure if just one or both because it got everywhere so im gonna replace both lines just to be safe and not have to go down there again. new o rings and new oil thermostat gasket.
Switchemlee
Has thanked: 0
Been thanked: 0
Switchemlee
Post by Switchemlee » Sat Apr 15, 2017 4:23 pm
Also are the o rings on both sides of the lines? Or just at the oil thermostat?
Has thanked: 102 times
Been thanked: 301 times
Post by erikv11 » Sat Apr 15, 2017 4:56 pm
Both ends have o-rings, of a sort. Each line has:
One standard o-ring at the thermostat.
One standard o-ring plus one seal plus that outer clip, at the radiator.
Check out Robert's video on replacing the lines, it probably shows what is on the ends.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
Switchemlee
Has thanked: 0
Been thanked: 0
Switchemlee
Post by Switchemlee » Thu Apr 20, 2017 10:50 pm
How do you tighten those clamps down?
Canada
Post by scot850 » Thu Apr 20, 2017 11:39 pm
Can you clarify what clamps you are asking about? At the thermostat end, the bolt in the middle of the pipes at the front of the engine block, or the cooler lines at the radiator?
If it is the first one, it is a Torx screw between the 2 pipe at the oil cooler end that holds the clamp bracket which holds the 2 pipes into the thermostat housing.
2006 XC70
Post by erikv11 » Fri Apr 21, 2017 1:06 pm
Where the cooler lines connect to the radiator, I use one thick zip tie around the clip as extra clamping insurance. Has been bombproof.
'96 855 NA, 145k
'06 S60 R, 167k
