Rule #1: check what you have in the car first!
My 1998 S70 GLT:
- NA axle on passenger side (dealer bought it at local NAPA and installed it for the P.O.).
- Turbo axle on left side.
I only found out after I took the right axle out for repair!!!
So, again, check what you have in the car first!
CV boots - quality? Topic is solved
- Has thanked: 134 times
- Been thanked: 371 times
This is great advice. Before you order anything eyeball the axle, figure out which kind it is. I had a similar thing happen to me, my NA had one turbo axle.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
gone: '96 NA 850 210k, '98 NA V70 182k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- Year and Model: 1998
- Been thanked: 2 times
Thanks for all the tips guys ... I will be sure to order GKN and to check both axles before I order anything.
current - 98 S70 T5 SE (255k km)
previous - 90 745T (400k km - sold); 94 855 T5 - (206k km - blown timing idler bearing)
- Year and Model: 98 V70GLT, 98 S70T5M
After looking through the service history record on my "new" S70T5m, I found the previous owner had recently replaced the axles, outer tie rods and sway bar links.
Axles - SurTrack brand
Tie Rods - Mevotech brand
Links - Altrom brand
I guess that explains why there's hella noise now coming from the axles and a slight oil leak and where the right shaft goes into the transmission after 5000 miles.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
I would be scouring the junkyards and part-outs for Volvo branded axles.
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- 17 Replies
- 1988 Views
Last post by sleddriver
- 972 Views
Last post by erikv11
- 283 Views
Last post by mika
- 1333 Views
Last post by 98v70dad
- 525 Views
